09-02-2015, 04:12 PM | #1 |
Drives: 2012 ZL1 Black Join Date: Aug 2014
345/35-18 on 18x11 factory repoductions
There are a lot that say the will not work??? But they fit mine even with the RPM roll bar bolts pushing out on inner fender wells. Changed from the Z06 9.5 wheels and Mickey Thompson ET street 305/45-18 to these.... Hoping to pin it down? Traction has been a big problem as we add more power and run unpreped tracks.
2012 BLK ZL1 A6
HP TUNERS W/WIDE BAND O2 ROTO-FAB ... UPPER & LOWER PULLEYS SQUASH DUAL PUMP E85...127# FIC INJECTORS D-STRECK FLEX FUEL SENSOR KOOKS 1 7/8 ... FULL 3" EXHAUST OUT THE BACK BRIAN TOOLEY STAGE 3 SELF TUNING HPtunners WELD DRAG PACK (Blacked out) Running mid 6's @ 105 mph (1/8 mile) 1.5's 60ft's Remote tuning by Steve 6L80etuning.com Last edited by jrmac; 09-02-2015 at 04:29 PM. |
09-03-2015, 04:45 PM | #2 |
Sarcasm loading --------
Any pics?
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
09-03-2015, 05:43 PM | #3 |
Will get some...did cut 1.6 60 ft times finally .... since cage install.
2012 BLK ZL1 A6
HP TUNERS W/WIDE BAND O2 ROTO-FAB ... UPPER & LOWER PULLEYS SQUASH DUAL PUMP E85...127# FIC INJECTORS D-STRECK FLEX FUEL SENSOR KOOKS 1 7/8 ... FULL 3" EXHAUST OUT THE BACK BRIAN TOOLEY STAGE 3 SELF TUNING HPtunners WELD DRAG PACK (Blacked out) Running mid 6's @ 105 mph (1/8 mile) 1.5's 60ft's Remote tuning by Steve 6L80etuning.com |
09-04-2015, 10:17 AM | #4 |
Drives: 2013 ZL1 Camaro Join Date: Dec 2010
Would love to see some pics of this if you ever get around to it.... Not only how they fit on the car but how they fit on that 11" wheel....
2013 ZL1 Camaro - Crystal Red Tint / A6
Best so far of 10.50 @ 134.50 w/ 1.58 60' on 20" Nitto NT05R's (Camaro5 Fest - Royal Purple Raceway) |
09-07-2015, 12:27 AM | #5 |
Photos
1 pic is the 345s vrs 305s Mickey Thompson mounted on wheels
2012 BLK ZL1 A6
09-07-2015, 06:20 PM | #6 |
11.91 ET Bone stock
Drives: 2015 Camaro ZL1 Join Date: Nov 2014
Awesome Can you post a big from the back of the car?
09-08-2015, 11:52 AM | #7 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Not to get off topic but jrmac who fabricated up your roll cage? or where did you buy it?
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
09-08-2015, 12:34 PM | #8 |
Drives: 2013 ZL1 White/Carbon fiber Vin#658 Join Date: Oct 2013
Air down?
How far have you aired them down at the track? At what pressure do you find best results?
09-08-2015, 12:58 PM | #9 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
09-08-2015, 02:12 PM | #10 |
Rpm cage....Air down to 16psi but after 3 hot laps they were 20...lol so this week we going lower on pressure and checking more often. Was more working on timing on car...keep adding and it seems too like it.... was very hot day so intake temps were running high but did get to 30 degrees timing and know knock....with expensive race e85 fuel.
2012 BLK ZL1 A6
09-08-2015, 04:22 PM | #11 |
Drives: 2013 ZL1 Join Date: Jan 2015
Any reason you can see why the factory 20" wheels wouldn't work with 325 or 345's?
2013 A6 ZL1
09-08-2015, 07:20 PM | #12 |
Nope i run 315 Nitto NTO5r"s on my 20's for street use. But they are nowhere as soft as the mickeys. ON street nitto's faint black marks, Mickeys DARK (last for year) black marks.
2012 BLK ZL1 A6
09-08-2015, 08:05 PM | #13 |
If need be I am going to get some 17" rts welds and mickeys but would like to get some sticky true street tires in a size that might hook up on factory wheels if possible. I have an auto which helps but make over 800whp which doesn't.
I am quite aware no true street tire is going to hook up as well as 17" mickeys or similar, but if I can cut 1.6 60' I will run the times I want and still have a car I can throw in the corners.
2013 A6 ZL1
09-09-2015, 08:21 AM | #14 |
Redlineviper.....if it helps....you shouldn't have any problem nailing 1.60's with the Nitto NT05R's on 20's. I managed 1.50's with mine. I would suspect it would be even easier if you ran the 20" Mickey's as well....
