Old 06-04-2020, 06:37 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
sway bars & links correct after coilover install?
Does anyone have pictures of their sway bars from underneath the car front to back after dropping at least one inch? Checking to see if mine are installed improperly causing it to be tight in steering.
edog is offline   Reply With Quote
Old 06-04-2020, 06:52 PM   #2
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
That’s correct as to the way the link is installed. Being 1” lower won’t affect anything. I don’t know about the steering issue
VR Baron is offline   Reply With Quote
Old 06-04-2020, 07:20 PM   #3
mikeman
Banned
Drives: 2015 Camaro
I'd invest in some adjustable end links so the bar ends don't hang that low.
mikeman is offline   Reply With Quote
Old 06-05-2020, 06:30 AM   #4
KillboyPowerhead
Drives: 2015 Z/22
Does look like the bar hangs a bit low from what I remember but I can't picture mine. Looking at some pictures it looks like the bar is tucked up in more as well. Can you rotate the bar inward, toward the back of the car? Shouldn't need adjustable links if lowering an inch or so. I'll take a peak under my car when I get out today, maybe I'm just crazy...
KillboyPowerhead is offline   Reply With Quote
Old 06-05-2020, 03:24 PM   #5
edog
edog's Avatar
Thanks guys. These are adjustable. Pedders, 2nd gen links and Sways. I will work to tuck them up. Thank you.
