03-20-2012, 10:16 AM | #1 |
Drives: 2011 V6 Synergy Green Join Date: Jan 2012
check this out
i made this in my photoshop class today. what do yall think?
03-20-2012, 01:37 PM | #2 |
So I'm guessing nobody likes it? Lol
03-20-2012, 01:41 PM | #3 |
Don't ask to pop my hood!
Drives: it's loud....... Join Date: Jun 2011
Looks like the cars are floating over the road lol,
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS | 2010. |
03-20-2012, 01:42 PM | #4 |
Camaro CRAZY
Lol. I like the concept. These are future cars! They fly!
03-20-2012, 01:50 PM | #5 |
502 RWHP N/A
Someone likes daft punk
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
03-20-2012, 01:54 PM | #6 |
Drives: Silver Bullet Join Date: Sep 2010
V6 with a mailslot, and what kind of mirrors are those ? Did you put it on truck tires ? The Ford and Dodge look fitting
03-20-2012, 01:54 PM | #7 |
Drives: Black 2SS/RS Camaro Join Date: Jan 2012
Zomg Drop Shadow on the cars quick. Your type is touching the edge of the image which is horrid.
Also the resolution difference between the cars and the background is huge so it makes the cars look like they are made out of plastic. That also seems to be the brightest stormy day I have ever seen. |
03-20-2012, 02:01 PM | #8 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
I was a graphic designer for years and taught photoshop, so you might not like my input. But if you want honesty, the depth perception is really off; it needs drop shadow badly; the three cars are all different shades/resolution/brightness/contrast and sitting at incorrect angles; too much blur (road); bad clipping masks (the cars look like they were cut out of a piece of paper and glued on the road); the Camaro needs serious work (mirrors? V6 fascia? tires?) and then the text needs to be killed-- changed entirely. And get it away from the edges.
The texture on the sky is awesome; but the yellow needs to go. Keep working at it; practice makes perfect in Photoshop.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
03-20-2012, 02:04 PM | #9 | |
Drives: 2011 Camaro 2LT/RS Black Join Date: Nov 2011
Thought of this. |
03-20-2012, 02:04 PM | #10 |
Drives: 2017 Corvette Grand Sport Join Date: May 2010
Cut him some slack everyone lol. Yes it does need some help/adjustments in some areas but its a good start. Keep at it
03-20-2012, 02:07 PM | #11 | |
Photoshop isn't easy! I have used it for almost a decade and am still learning.
03-20-2012, 02:12 PM | #12 | |
Your such a meanie I think your concept was fun, but for technical skills it needs some work. I also have over 10 years of working with photoshop and it is a skill to know all of your tools and how to use them. Keep practicing |
03-20-2012, 02:23 PM | #13 |
Two Miles An Hour
Drives: SIM 2LT RS Join Date: May 2010
In his defense, I believe that is the concept camaro. The turn signals are on the outside of the head lights, the lower grill is smaller than on a production v6, and it has those slot lines under the bumper.
expect nothing, but take everything |
03-20-2012, 06:26 PM | #14 |
Lol I'm only 17 and a junior in highschool in a photoshop class just messing around. what do yall expect? im not a professional.
Similar Threads | ||||
So if You Get a Constant (not flashing) Check Engine Light... | Hicompression | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 12-21-2011 08:14 AM |
My check engine light cleared itself! | 73duster | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 05-05-2011 02:14 PM |
Question about Check engine light | Alain | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 03-11-2011 11:42 AM |
Those with LT's, RESET your check engine light! | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 107 | 08-18-2010 01:51 AM |
Is There A Better Way To Check Your Status besides VIZ? | camaro19672010 | 5th Gen Camaro SS LS LT General Discussions | 21 | 11-07-2009 07:36 PM |
