04-06-2014, 03:26 AM | #1 |
Supercharger?
I just got a 2014 Camaro 1LT in January and I am looking to get a supercharger or a turbo kit in the next few months. I am also a little car retarded and am not sure what exactly I should get.
04-06-2014, 08:03 AM | #2 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
You should buy the IPS/Fabberge Twin Turbo kit!
04-06-2014, 08:48 AM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Yeah, IPS offers a twin turbo kit, as does Fabberge. IPF makes a supercharger kit.
04-06-2014, 11:13 AM | #4 |
KaBoom1701
IPF is the only brand I would consider...all others are a mess.
Mods:
04-06-2014, 12:11 PM | #5 |
04-06-2014, 12:38 PM | #6 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
The IPF Supercharger kit has been out for awhile and so far seems to stand the test of mileage. Being a 2014 you should have no trouble tuning this setup.
For me being in in New England and this being my almost daily driver I wanted a kit that would also get washed with road chemicals during the winter time. The dual turbos leave a lot of hardware exposed and most of these kits were developed with warmer areas in mind.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
04-06-2014, 12:52 PM | #7 | |
04-06-2014, 01:11 PM | #8 |
Absolutely right on torque. The twin turbos will give more. Surprising a bigger company hasn't come out with a whipple for the LFX yet considering there are tuning available.
I don't drive mine in bad weather it's just amazing the chemicals left on the road that gets kicked up.
04-07-2014, 08:35 AM | #9 |
The IPF supercharger is also has sealed bearings. meaning oil is selfcontaining. The oil doesn't have to be fed by a pump.
04-07-2014, 09:45 AM | #10 |
Thunderfury
Drives: 2013 Dusk Edition 2SS M6 1/205 Join Date: Mar 2014
I'm glad someone posted this thread. My friend and I have been discussing if we want to Supercharge or Turbo our car (I have a LLT Engine 2011 and he drives a 2014 Mustang V6 so TT isnt available for him and a little out of reach for my engine with tuning issues atm). We're both using them as daily drivers and as VA wants to be bi-polar as shit weather is an issue here even if we keep our cars super clean. I generally know SC vs Single Turbo SC can give a little more low-end torque (depending on car) but Turbo is easier to get the more HP w/ a tune and psi increase.
Any thoughts on what we should do? We're in an agreement if one gets FI we would get the same FI.
Current Car:
2013 Dusk Edition 2SS/RS M6 1 of 205!!! CAI Intake, GM Perf Exhaust, RX Catch Can "Thunderfury" Old Car: "Blu Bee" 2011 Camaro LS Imperial Blue HURST Short-Throw M6 --You will be missed good buddy-- |
04-07-2014, 10:11 AM | #11 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
A turbo will make more low end torque than a centrifugal super charger. You won't see a whipple/roots kit from the bigger companies to to the fact it won't clear the stock hood.
04-07-2014, 10:19 AM | #12 | |
Don't Sleep on My V6
You looked at IPF record lately with the revamps on their kits that have had to be made? IPS the only turbo company out but also has built theirs without any issues other than tuning for the LLT. And they tuned their LLT build perfectly to this day. Not picking sides just stating facts. Turbos all day long as you can adjust the power on the fly with the turn of a knob or button.
04-07-2014, 10:50 AM | #13 | |
Always bet on Black
Drives: 2011 turbo LS, 2012 f 150, Join Date: Nov 2010
Sent from my SAMSUNG-SM-N900A using Tapatalk 4 |
04-07-2014, 01:52 PM | #14 |
I totally agree that with any FI system you have to pay to play.
The only issues with the IPF SC kit was the idler bearing problem which was fixed by IPF. There are other changes to the kit that people have done to improve on the system, as I have. But the kit as delivered does what's its suppose to do. I have done FI updates to other cars and there are always tweaks that were done. A lot of R&D $ goes into oem hardware before it ever hits the street in a test vehicle.
