Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Members Area > General Automotive + Other Cars Discussion
Old 10-20-2017, 03:41 PM   #1
2010_camaro's Avatar
Drives: 2014 Camaro SS
Not camaro related but ls question
Ok so I'm helping a friend put a 5.3 truck engine in his 74 Stingray. Car has the factory th400 in it. What do I need to adapt the engine and trans together?
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
2010_camaro is offline   Reply With Quote
Old 10-20-2017, 04:31 PM   #2
Drives: 2010 Camaro SS 2SS
A foundry
JOURDAN is offline   Reply With Quote
Old 10-20-2017, 04:37 PM   #3
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS L99
New flexplate, crank spacer. Fairly certain it will bolt up, although you may have a couple unused bolt holes.
There is certainly more to this, but that's what I know of. I think Bo White is running a TH400 in his Camaro, so maybe PM him?
2010 Cyber Gray Metallic Camaro 2SS/RS L99 - Texas Speed Longtubes (Catless), Summit X-Pipe, Flowmaster Outlaw Axle Back (w/MBRP GFX Tips), Vararam OTR CAI, Granatelli wires/AC Delco 41-110 Plugs, 160* Stat, LED DRL/Harness, Vitesse Throttle Controller, STOP-TECH Slotted/Cross Drilled Rotors w/Hawk HB453Z.585 Performance Ceramic Pads, ZL1 Leather Steering Wheel, ZL1 Add-Ons Wicker Bill Spoiler, SLP Front Splitter - Tune by DynoSteve
Old 10-20-2017, 09:23 PM   #4
rshelar's Avatar
Drives: 2015 Camaro 2SS vert 6.2L L99 Auto
I have a 5.3L in my 2004 Silverado and love it. 150k miles and no problems. The show Iron Resurrection just put a used 5.3 and matching trans in an old Metro van. Not sure why you drop in a plant that doesn’t marry up to your trans. Good luck!
Chrome plated OEM wheels
Eibach PRO-KIT springs (1" drop)
Magnaflow muffs, resonator delete
Rear wing black, vinyl added to hood
rshelar is offline   Reply With Quote
Old 10-20-2017, 10:05 PM   #5
Drives: 2015 1LE
contact advanced adapters. they will hook it up. heard this on a daily at summit racing
Coz3z3 is offline   Reply With Quote
Old 10-20-2017, 11:27 PM   #6
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
You're either looking at an adapter kit like mentioned above, or you get a TH400 that's designed to bolt up to an LS-style block.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
BMR 1" lowering springs, trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified FULLY 3" Magnaflow competition catback. CAI cold-air intake. Tuned by Ronnie @ RS Motors in Burnsville.
438 WHP, 406 WTQ on a Mustang Dyno
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 10-21-2017, 12:05 AM   #7
wildchevy's Avatar
Drives: 2014 Blue Ray 2SS
I did a google search a search with your question here is the first result.
wildchevy is offline   Reply With Quote
