Flowmaster Exhaust
Old 10-20-2017, 09:34 PM   #1
Thr3zus
Thr3zus's Avatar
Drives: 2013 Camaro SS
Ported Heads?
Where is the best place to buy ported heads for my L99 2013 Camaro ss?
Thr3zus is offline   Reply With Quote
Old 10-20-2017, 10:44 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
GMPP CNC from any of the sponsors... they will give you their best price, RDP, GPI, JDP, etc... just to name a few...
-Don
Old 10-20-2017, 10:55 PM   #3
Thr3zus
Thr3zus's Avatar
-Don
Can you explain more I am a novice at this a need some help
Old 10-20-2017, 11:25 PM   #4
hammdo
hammdo's Avatar
General Motors Performace Parts heads that have been CNC ported.
http://www.superchevy.com/features/s...-and-cam-test/
Usually install heads when doing a cam/lifters.
Google GMPP CNC LS3 heads, that will get you started...
-Don
Old 10-20-2017, 11:47 PM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Why not just send them in for a do over at Frankenstein, Texas Speed, GPI etc..lot of them have sales and/or will made you a deal...plus you should have somebody look at the entire combo cause to make use of any mods you gotta tune...good luck!
2010 SS 2SS M6-Spectre CAI-JET TBS-JBA Shorty Headers-ARH H/F Cats-Doug Thorley axle back-MSD 12v coil harness mod-PAC 1218's-BTR 3/8 7.4 push rods-Powell Machine bronze rocker bushings-Prothane motor mounts-Prothane rear sub-frame inserts-BMR Trailing Arms & bushings-1LE 3.91's-1LE axles-Ford S-spring posi-mod-Tune by RDP dynoSteve!(Woot)-LS9 block-Daily Driver-117K!-12.7 at 112-1.9 60'(3.45's)-BFG Comp-2 Street Tire-stock size on ZL1 reps(20x8.5)(20x9.5)-DR's Nitto NT05R(305/45) on Motegi MT120 18x9.5-12.3 at 110-1.7 60'(3.91's) All work by me...
frankwjr is online now   Reply With Quote
Old 10-20-2017, 11:57 PM   #6
JOURDAN
Drives: 2010 Camaro SS 2SS
OP, Is there a Tuner in your area? Are you close to Columbus?
Dyno Tune Motorsports may be able to help, they build some bad ass Camaro's
Sometimes its best to start a communication with a tuner before you buy anything. This way they can educate you about all the variables involved and where best to acquire the recommended parts.
JOURDAN is offline   Reply With Quote
Old 10-21-2017, 07:15 AM   #7
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
we can certianly help you feel free to give us a call sir
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power HP Tuners Ngauge Diablosport SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC
dynosteve is offline   Reply With Quote
Old 10-21-2017, 08:22 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
I purchased mine through Summit. or you could just wait for some place to do your own heads which for most shops can range in the ?????$$$$$ area if not using the factory CNC jobs....AS your factory heads have solid intake valves the GMPP heads come with hollow stem intakes for bonus to help top end stability for higher revs..one reason the l99 has lower top rev limit.
Mine cost back when I got them under $1400 for a set, some places charge $800 ish just to hand port your heads after cleaning them up and then you still have to buy new valves if you want to upgrade, some places are cheaper but most do coast around that range just to do your heads....not exactly a bargain.
The best deal out there though is from a dealership that actually freshens up and touches up the factory CNC job called Dickey Scoggins and gains a little more power.
The thing is unless your going all out FI, Stroker, Big Big cam your gains may be about squat with heads being ported as our factory heads flow more than BBC heads ported to the max....Just like our factory intake the heads are pretty much that good... And believe me I studied up everywhere on flow and output numbers before going factory which can out flow and make more power than most shops hand porting which is just well...sad...LOL And yes a bargain and someday when I have money again I can go small bore ls7 ...LOL
Now factory CNC heads are 150-200 more than stock heads, not much combustion chamber porting but its in the runners, and for different usages there lots of different ways to port heads for use and different chamber sizes you can go with or aftermarket heads but with those you make a more specific use heads of far more expensive and investment in heads which are not the most cost effective use of $ but are great when its a more all out build to help flow and power. Its kind of like the FAST intake....not so much a gainer for a stock or mild build in terms of $ per HP.
And we all know money does matter, and the factory heads have the same clearances for deck height to know when building a engine/ cam selection etc.....But basically the factory heads come with springs that are crap beehives not even good for the factory cam. Now on here is a guy named Bo White who does port out some heads for what may be a decent price for a hobby not a business, people even port there own if like me they have done it before and know what they are doing with the correct tools it about massaging out material to increase flow so therefore runner size and shape and chamber volumes and shape can matter for flame over, torque or HP production and best rpm range for power etc...... Well there you go my morning rant MURR in the morning LOL
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
christianchevell is online now   Reply With Quote
Old 10-21-2017, 11:18 AM   #9
Gasoholic
Gasoholic's Avatar
Drives: Inferno Orange 2010 SS LS3 M6
I got mine from Livernois.
"Burning Hard Loose and Clean
Quench My Thirst with Gasoline"
Gasoholic is offline   Reply With Quote
Old 10-27-2017, 09:34 AM   #10
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
We've got Stage II and Stage III CNC ported heads and we offer them through a Core Exchange program. We also offer the GMPP heads as well if you want to go that route. Please feel free to call or email us anytime with questions.
Kind regards,
Jordan Priestley
801-545-4215
JDP Motorsports is offline   Reply With Quote
Old 10-27-2017, 10:02 AM   #11
Kelly@PCMofNC
Drives: 2010 RS/SS
I use Advanced Induction almost exclusively for our head work. Repeatable performance, excellent gains, they really know their stuff. A set of those & our Phoenix cam is a super popular package that we install all the time here.
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
