Old 11-16-2009, 02:42 PM   #1
bng804
bng804's Avatar
Drives: '10 Victory Red 2LT
Need amp/sub install help
Ok, my wife decided she wanted add a little kick to the BA system, so I had a little project this last weekend.
I had a Alpine V series amp and P2 12" sub sitting around that I pulled out of my old car, so I decided to recycle. :-)
Now I'm certainly not a car audio expert, but I've installed a few systems before so I'm not a total idiot. I picked up a 4 channel Scosche line output converter at the local wally world. Why 4 channel? Cuz that's all they had. I figured I could just use one side and maybe that is my whole problem....
Anyway, installed and wired the amp, tapped the pre-amp signal for the rear speakers and then tested it out. It sounds like crap! Very muddy and the level is way too low. I know how the combo sounds since I had it in my old car, so I know something is wrong.
So I cranked the converter output all the way up, and the sub level as well and it sounds "OK" but the level is too low and not particularly clear. It should hit much harder. I would normally have to cut the amp level way down to keep the bass at a listenable level.
I'm 99% sure it's in phase, as I switched up the +/- and it sounded even worse.
So I'm thinking maybe the 4 channel converter doesn't like to run only too channels? Or maybe I need to tap the post-amp signal? Ideas?
bng804 is offline   Reply With Quote
Old 11-16-2009, 07:56 PM   #2
camaroguy
MJ is finally home!
camaroguy's Avatar
Drives: 2010 CGM 2SS/RS Camaro M6
eliminate the converter and see how it sounds. If you are feeding off of the low level inputs from the head unit, converting them again with the schoshe unit should not be needed..
camaroguy is offline   Reply With Quote
Old 11-16-2009, 08:10 PM   #3
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
pick up the signal before the amp....its located in the rear driver side in the trunk behind the plastic and side rug. there is a sticky on the top showing which plug it it and which are the signals
also try this thread it shows the location and the wires
http://www.camaro5.com/forums/showth...ht=factory+amp
Ltdodge is offline   Reply With Quote
Old 11-16-2009, 08:12 PM   #4
latinoslife
Drives: silver ice 2010 camaro 2lt RS
a shop did mines all they did was split the RCa's
[IMG][CENTER][/IMG]
latinoslife is offline   Reply With Quote
Old 11-16-2009, 08:24 PM   #5
bng804
bng804's Avatar
Interesting. I never thought of that, but it makes sense. If it's a pre-amp low level signal, there shouldn't be any need for the converter. I'm gonna try it tomorrow and will report back. Thanks!
Old 11-17-2009, 10:28 AM   #6
1badtie
1badtie's Avatar
Drives: 2018 Camaro ZL1
i recently got a 2ss and thinking abt putting some subs in the trunk does anyone know if itwill void my warranty??.... any help is appriciated.
1badtie is offline   Reply With Quote
Old 11-17-2009, 12:31 PM   #7
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
No, it won't void your warranty.
UCF w00t is offline   Reply With Quote
Old 11-17-2009, 12:57 PM   #8
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
well I can see how it could void certain aspects of the stereo, such as factory amp or speakers if you tap into those.
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 11-18-2009, 03:47 AM   #9
R9808
Drives: '10 Black SS, '95 White Convertible
Put the GM subs in and it is covered by your warranty. Part #92213214.
R9808 is offline   Reply With Quote
Old 11-18-2009, 08:06 PM   #10
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
Thumbs down Please
Are you for real>???????
Alfieboy is offline   Reply With Quote
Old 11-18-2009, 09:46 PM   #11
R9808
Sure, all GM accessories are covered by the remainder of your GM factory warranty if installed by a GM dealer. The GM subs (by MTX) are a GM Accessory. For real...
Old 11-18-2009, 09:49 PM   #12
latinoslife
i wouldnt man that a waste of money i spent 650 dollars to put that 12 in my trunk and man im putting people to shame with 2 12's you just gotta know where to go
[IMG][CENTER][/IMG]
Old 11-19-2009, 04:32 PM   #13
bng804
bng804's Avatar
Ok, finally got a chance to rewire today. I eliminated the line converter as recommended and just stripped my patch cable and tapped the rears before the amp. Oh man, what a difference. Sounds great now. Makes sense now that I think about it, as the signal before the amp is already line level, there is no need to covert it.
I wasn't real impressed with the BA system before, but just the simple addition of a single 12 really does wonders.
Old 11-19-2009, 10:12 PM   #14
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
This is an after thought now that your issue is settled, but I have always found the Scosche line converters to be absolute junk. I have two in my tool box that I used for 10 minutes. Garbage. Don't even know why I've kept them except it felt too much like throwing away money if discarded new.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 01:25 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
STEP BY STEP VIDEO INSTALL OF MGW SHORT THROW SHIFTER>> MGW Camaro DIY & HOW-TO instructions & discussions 39 12-02-2011 10:25 AM
M45 Blinder X-treme laser jammer install klove Camaro DIY & HOW-TO instructions & discussions 7 12-10-2009 03:39 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
