04-03-2019, 08:10 AM | #1 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Hp Turners and Mace Cams
Anyone on here have any experience with HP Turners And Mace Cams
I'm having to do a Head Gasket Install and would like to get Mace Cams, but i've been told you need to tune the cams, and HP Turners is the way to go. I'm buying the HP Turner Program, For the Headers anyway.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
04-03-2019, 09:32 AM | #2 |
Drives: 2014 LS Camaro Join Date: Jan 2019
Go to FB 5th Gen V6 Performance Group...Ask the same question and you will get great information
04-03-2019, 10:38 AM | #3 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
It is what I use on my LLT. You can drive it without a tune, just won't be as good as it can get. The cam timing needs a lot of adjusting. Thankfully I have all that information for the LLT with headers from my tuning.
04-03-2019, 11:25 AM | #4 |
Thankyou i was on the fence with the cams
I've got to replace Head Gasket, so i'm replacing Timing Chains and i might as well rebuild heads and replace cams
04-03-2019, 05:37 PM | #5 |
I was in the same boat, except it was cylinder heads I needed replace since I broke several bolts in them.
04-04-2019, 01:19 PM | #6 |
Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6 Join Date: Dec 2016
Magnum would you mind providing that information for the cams?
thanks!
CamaroLIFE
