07-21-2010, 01:58 PM | #1 |
Drives: 2010 CAMARO 2SS/RS LS3 VR Join Date: Mar 2010
INTAKE MANIFOLD COVER REMOVE FOR PERFORMANCE
I was wondering if anyone new the purpose for the two intake manifold covers, and fabric liner on bottom side of the hood other the cosmetic apperance.
Do you think it is to keep the heat in for winter or sound deadning? 1. black and silver or painted to match piece on top w/ fabric on bottom side. 5 lbs 2. black piece the follows the contour of intake underneath the top one. |
07-21-2010, 02:00 PM | #2 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
Maybe some sound deadening.... but mostly it's for looks.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
07-21-2010, 02:12 PM | #3 |
Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
The fake intake cover ie.. clamshell is to keep you from hearing the valvetrain that is very noisy that everyone complains about on the older ls motors. the engine cover is mostly for appearance.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
07-21-2010, 02:18 PM | #4 |
Drives: 11 2SS/RS E-Force Supercharged Join Date: Apr 2010
I can clearly notice the increased noise from the motor with the cover off.
07-21-2010, 06:22 PM | #5 |
MURC 666
Drives: 69 Pace Car 68 Camaro Restomod 81 Z Join Date: Jan 2010
I ran mine with the cover off for a short while , then decided the cover was there to insulate the intake from engine compartment heat so I reinstalled it .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it ! |
07-21-2010, 06:44 PM | #6 |
And the hood liner is there mostly for noise reduction into the cabin.
07-21-2010, 07:19 PM | #7 |
Drives: 1969 Pontiac Firebid Join Date: Aug 2009
The covers are there for sound deadening. The intake cover does not protect the intake from heat, it would retain heat. It muffles the injectors pulses and valve train noises.
The reason car weights as much as it does is because of the added sound deadener, insulation etc. Its amazing how that stuff all adds up. My friends shop saw a huge timing full with the big cover on the engine from heat soak.
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler 1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me |
07-21-2010, 07:27 PM | #8 |
ZL1
Drives: 10' SS/RS - Sold; 15' White ZL1 Join Date: May 2009
So it's actually ok to take off both of these covers?
07-21-2010, 07:29 PM | #9 | |
I used to be Dragoneye...
Yes, it is! As long as you don't mind a little added noise. |
07-21-2010, 09:20 PM | #10 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
also do the heater hose mod, re-route the heater hoses off the top intake!
07-21-2010, 11:32 PM | #11 |
Drives: A wrench Join Date: Jan 2010
Those 2 covers are completely useless and YES, they do rob power due to heat soak. Take them off. I removed them on all L92/LS3 powered cars.
07-22-2010, 12:33 AM | #12 |
Drives: 2010 Camaro SS Join Date: May 2010
I said this 4 months ago when we tested on the dyno
ITS CALLED COMMEN SENSE
SOLD
2010 Camaro 1SS/A6 12.59@111.31 Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned |
07-22-2010, 06:23 AM | #13 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Hey, those are my intake covers laying on my driveway.
I took them both off a while back (and took a pic) at the advice of my tuner. The intake cover (small cover) has insulating foam that definately acts like a blanket. The day we took the engine cover off my car (hot engine after driving 100 miles in 90 degree heat) a big rush of hot air came out from under it. But as far as increasing HP (I dought it). But I do believe the engine will cool down faster with the covers off (especially at the track with the hood open). |
01-29-2014, 10:42 PM | #14 |
Drives: 2SS Transformer Eddition 2012 Join Date: Jun 2013
How do you remove iNtake cover there's so many bolts and screws and wires going everywhere
Similar Threads | ||||
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
Intake Manifold cover | trudawg660 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 06-16-2010 08:09 PM |
