09-29-2011, 08:52 AM | #1 |
Drives: 2010 SW 2SS M6 Join Date: Apr 2010
Are these replicas the exact same size/bolt pattern/offsets as OEM?
Http://www.pinnaclecamaro.com/2010_2...p/fr-c101b.htm
Thanks! I just need to know if they're the correct size to fit my stock tires on my SS Edit: Also, do I need to buy the sensors and whatnot for them also? (Sorry still learning!) Edit2: I was looking at... 20x8 35mm offset (x2) 20x9 40mm offset (x2) Last edited by Steers; 09-29-2011 at 09:08 AM. |
09-29-2011, 09:35 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
well the offsets are RIGHT. as far as the sensors go, you can use the ones in your current wheels.
as far as the bolt pattern goes....since they are FACTORY REPO's...they SHOULD be correct....what I would do is actually call them and see if you can get a TRUELY knowledgable person on the phone.....not just someone taking orders. The reason I ask that is because on their website is lists the bolt pattern as 5 x 4.75".....which is the OLD STANDARD CHEVY bolt pattern....our cars wheel bolt pattern is in reality 5 x 120 mm. which is a hair different. IF you can talk to someone that really knows his/hers product....they can most likely verify that they wheels are truely the SAME as the factory wheels which are 5 x 120 mm.....and not 5 4.75" as listed on their website.
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
FS - OEM SIM Hood, Trunklid, Spoiler, Fenders | Maro99 | Exterior Parts & Accessories | 27 | 10-27-2011 09:43 AM |
Camaro OEM Wheels and Gorilla Wheel Locks | shiftz33 | Wheels and Tires Talk Sponsored by The Tire Rack | 26 | 09-20-2011 05:46 AM |
F/S: OEM SS Spoiler (Black) + OEM Grille w/Bowtie included | FINALLYSATISFIED | Exterior Parts & Accessories | 5 | 09-26-2010 06:53 PM |
5th Gen OEM Fit SS Brake Lines | JusticePete | Suspension / Chassis / Brakes | 5 | 12-01-2009 10:56 AM |
