06-11-2012, 12:41 PM | #1 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Will auto trans get 2nd gear rubber
I'm still trying to take it easy on my car and have less than 1000 miles, so I haven't really opened it up too hard yet. I've noticed the trans may shift faster in Sport mode, but not much firmer than Tour. Will the auto trans get 2nd gear rubber under heavy throttle?
06-11-2012, 12:54 PM | #2 |
Drives: fast car Join Date: Apr 2012
It grips nicely in all gears surprisingly due to the tires with or without traction
06-11-2012, 12:57 PM | #3 |
06-11-2012, 02:01 PM | #4 |
Drives: '98 Camaro Z28, '06 Z06 Join Date: Feb 2011
I would hope so, my SS chirped 3rd with a tune.
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con., shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's '06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles, Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP http://www.camaro5.com/forums/showthread.php?t=235911 |
06-11-2012, 05:57 PM | #5 |
I guess I'll have to wait until the 1500 mile mark to find out. Surely another forum member has run theirs hard enough to find out.
06-11-2012, 09:25 PM | #6 |
Drives: '21 ZLE A10 Join Date: May 2012
mine doesn't...shifts hard and quick though
06-11-2012, 09:31 PM | #7 | |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
The problem is if you let the trans shift itself, you are starting in 2nd and shifting into 3rd. To go from 1st to 2nd, you need to use tap shift and first is pretty much useless.
06-11-2012, 09:33 PM | #8 |
Drives: 2013 ZL1 IOM Vin #169 Join Date: Jan 2011
Mine will
06-11-2012, 10:22 PM | #9 |
Boss Killer
Drives: 2012 ZL1, Black, A6 Join Date: Feb 2012
i've launched hard and gone 0-120 mph. no real chirp. the computer pulls power so u don't put it in a ditch.
I was on the highway Sunday and punched it at about 60mph. The tranny downshifted, the supercharger got spooled up and started screaming! The traction control lights shot up for a few seconds. Thats power... breaking the tires loose at 60+
1100 : 2-6-12 Order placed at dealership, QDQS6G
2000 : 4-21-12 Oder accepted by GM 2500 : 4-24-12 Order preferenced. Order pulled into production 3000 : 4-25-12 Order accepted by production control 3300 : 5-10-12 Order scheduled for production 3400 : 05-15-12 - Order Broadcast (internal plant paperwork order produced) 3800 : 5-23-12 - Order produced VIN 1477 4000 : 5-23-12 - Vehicle available to ship 4150 : 5-23-12 Invoiced (order is invoiced to the dealer) 4200 : 5-26-12 Bayed waiting transport 5000 : 6-6-12 Delivered to dealer |
06-12-2012, 04:43 AM | #10 |
Slingshot, I understand from the owners manual that Sport mode starts in first gear and has quicker shifts as opposed to Touring mode which starts in second gear.
06-12-2012, 05:03 AM | #11 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Trans. goes to first gear any time except when in Tap Shift mode.
While using the Tap Shift feature, accelerationthe vehicle will have firmer, quicker shifting for increased performance. The driver may use this for sport driving or when climbing or descending hills, to stay in gear longer, or to downshift for more power or engine braking. The transmission will only allow you to shift into gears appropriate for the vehicle speed and engine revolutions per minute (rpm). The transmission will not automatically shift to the next higher gear if the engine rpm is too high. If shifting is prevented for any reason, the message SHIFT DENIED will appear in the DIC, indicating that the transmission has not shifted gears. While in the Tap Shift mode, the transmission will not automatically downshift on hard When coasting to a stop, the Shift controls.V6 transmission will automatically downshift to 1 (First) gear, and the V8 transmission will automatically downshift to 2 (Second) gear. A 1 (First) gear start can be selected using the Tap Shift controls on V8 models. When accelerating from a stop, the transmissions will hold these gears until the driver manually selects higher gears using the Tap
06-12-2012, 06:57 AM | #12 | |
The only time the trans will start out in 1st by itself, is on a cold start and putting it into a forward gear for the first time.
06-12-2012, 07:46 AM | #13 |
So, i guess the car doesn't feel as quick from a stop because I've never used first gear after the first shift after starting the car. It won't get rubber in second gear because it is really third. I wonder if a tune can correct this. To drag race, would I have to put in manual mode using the gear selector, manually downshift to first at a stop, and then shift to drive after taking off to let the trans shift itself?
06-12-2012, 08:03 AM | #14 | |
