01-16-2014, 02:21 AM | #1 |
Drives: 2012 2LT 45th anniversary convert Join Date: Apr 2012
Rear window replacement
After 5 weeks, my dealer finally got my replacement top to my satisfaction. But now 2 lines on the rear window defroster do not work. Now they are telling me that they will have to replace the entire rear window to fix this. I don't know how they are going to get the window out of the convertible top and put a new one in. I am just afraid that it is not going to be as good a job as the factory installed one, and they will screw up my new top after it took so long to get that right. Has anyone ever had the rear window replaced?
01-16-2014, 04:53 AM | #2 |
The rear window is integrated into the top. I think that means yet another new top
Let us know
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
01-16-2014, 09:42 AM | #3 |
Yes, that is what worries me. They think they can take the window out of the top and replace it in the current top. I don't see how they can do that and have it the same as from the factory. They are supposed to be having an outside glass company do it.
01-16-2014, 12:21 PM | #4 |
Drives: 2012 1SS Camaro Convertible Join Date: Sep 2010
There is no provision to replace the rear window without replacing the entire top. For them to attempt it, they would have to cut the seams, and restitch the entire window back in. IMO I would not let them try this. You are just asking for trouble and leaks down the road. Along with the visual appearance of what they did to it. Good luck and keep us posted on what they decide to do.
2012 1SS Crystal Red Convertible
"Cherry Bomb" Winner of the #NameThatCamaro Spring Special Edition "Green Flash" |
01-16-2014, 05:34 PM | #5 |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
Rear window defroster grids can be repaired, you should not have to replace the entire back window. There is a metallic glue-like substance used for this that will link the usually tiny broken grid gap(s). I have done this on cars back in the 80's and '90s before I started buying newer ones.
I would ask my dealer or other reputable repair shop about this possibility, and save the $$$$ and potential issues associated with window/top replacement.
01-16-2014, 05:39 PM | #6 | |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
Bye bye, Bumblebee!
01-16-2014, 08:25 PM | #7 |
Drives: '12 2LT Convertible Join Date: Mar 2012
So a broken rear window means a new top?
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
01-16-2014, 09:26 PM | #8 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Absolutely!! Anybody that tells you otherwise doesn't know what they are talking about.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
01-17-2014, 04:30 PM | #9 | |
They are insisting the rear window has to be replaced, and they will have it cut out of the top and replaced. I refused to let them do this, and I am picking it up tonite. Usually they are very good at this dealership. So I do not know what is going on with this. I guess maybe I will have to check with another dealership and see what they have to say. |
01-18-2014, 02:15 AM | #10 |
"Catharine"
Good luck, linc400. Please keep us posted.
