03-24-2013, 07:59 PM | #1 |
Drives: 2013 ZL1 Join Date: Mar 2010
Headers & High Flow Cats
Hello,
I have a 2013 ZL1 and looking into high flow cats and headers. I am think of getting Stainless Steel Works package. Will upgrade of headers and high flow cats void my factory warranty? What is your suggestions? Thanks |
03-24-2013, 08:03 PM | #2 |
Drives: 18 ZL1 A10 & 18 2500HD Duramax Join Date: Oct 2012
Yes because you'll going to need a tune with the headers
Procharged 2018 ZL1 A10
2018 2500HD Duramax |
03-24-2013, 08:32 PM | #3 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
The headers and mids are normally not a warranty issue. Most headers require tuning the car however because the new high flow cats throw check engine lights. The only header set up that does not require cats is Kooks header with green cats. We have sold a several sets of these with great success. If you have questions, call us @ 443-730-9428!
03-24-2013, 08:38 PM | #4 | |
"Cam Only"
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
03-24-2013, 08:55 PM | #5 |
We can..however any LT headers would not be legal for use in CA, no matter what kind of cats you have. They are for off road use only. You would buy with that understanding.
03-24-2013, 09:19 PM | #6 |
"Cam Only"
Goooootcha.
03-24-2013, 10:45 PM | #7 | |
Drives: 2012 CHEVROLET CAMARO ZL1 (BLACK) Join Date: Aug 2011
It's on a case-by-case basis. Take that for whatever it means. I'm pretty sure if my engine gets blown up, my warranty is out the window but as far as little stuff, they might warranty it. Just for info, I just went thru this whole warranty ordeal with a tuned zl1. |
03-25-2013, 08:59 AM | #8 |
Drives: 2012 ZL1, 2009 CTS-V Join Date: Jun 2011
Every dealer is different but it is great for all of us to see that GM took a look at your file outside of the dealership level and did not void your warranty.
Good luck getting everything sorted out this week. Let me know if you need anything. |
03-26-2013, 08:18 PM | #9 | |
Drives: 2002 BMW M5 Join Date: Jun 2011
Do you have any videos of your car?
03-27-2013, 07:39 AM | #10 |
Drives: 2012 ZL1 IOM#1645 Join Date: Mar 2012
Installed SW long tube headers and their high flow cats , my question is will this mod throw a code for sure or not? I'd like to get through this year without a tune if I could. Pro's or con's if I don't do the tune? I do know I can get little more HP with a tune! Thanks Todd
03-27-2013, 09:14 AM | #11 |
Drives: 2013 1SS Camaro and a truck Join Date: Apr 2011
I just installed longtubes and High Flow cats last Thursday. First day no codes, second day codes all the way till yesterday. I pulled the negative battery cable yesterday evening. No codes since 5pm yesterday.
03-27-2013, 10:33 AM | #12 |
Aikman Performance Tuning
just curious, how about installing long tubes and high flow cats, then doing the fuse pull? wouldn't that reset the adaptive fuel trim data? to make it relearn.
03-27-2013, 10:35 AM | #13 |
03-27-2013, 10:58 AM | #14 | |
Drives: 2013 ZL1 Join Date: Oct 2011
in theory the GM/Dealer has to prove that the mod contributed to the failure. headers an tune add power though so if you had a drivetrain issue they could lean back on the addd power. if you stereo stopped working or something though it is not like they can say more power caused that. Our Ram is moded 6" lift, tuner, etc, etc and our dealer still did work for me. front coupling ujoint went out. I would have denied me. 37" tires extra 125hp 250lbs of torque. they fixed it. everybody on the web will try to tell you how they think it will go but your dealer and GM are the ones that approve or deny waranty and I can tell you that all dealers are not consitant on waranty work. there are mod friendly dealers out there.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
