01-28-2017, 12:03 PM | #1 |
Drives: 2010 5th gen camaro 2ss LS3 Join Date: Sep 2015
Oil pressure sensor reading high
Hey everybody so hopefully I can get some advice from you guys. I'm pretty sure the oil pressure sensor went out because even when the car is off it's a reading at least 80 and when the car is on it's at almost 120 PSI but the car is running perfectly fine so that's why I figured it's the sensor. Should I be able to drive the car back and forth to work? I wouldn't be able to get the part until Monday and wait until Thursday to install it?
01-29-2017, 09:00 AM | #2 |
old school chevy rodder
Others have had to replace them I guess they are a PITA because of the location at the back of the intake manifold close to it so you may need a special tool, and may want to check the electrical connection to it. Good Luck, sounds like the sensor. And its just a simple R/R but tight space due to the engine compartment.
01-29-2017, 01:48 PM | #3 | |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Tele-tale sign is when off but key on if its reading maxed out or half (anything but 0) theirs an issue. Obviously like the previous poster said make sure the wires arent damaged (i doubt they are).
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
01-29-2017, 04:02 PM | #4 |
iv removed the intake manifold befor I think id would do it again if I ever had to replace that sensor. Iv never removed one on a Camaro So maybe try it 1st. I have big hands and a bad back.
01-29-2017, 08:15 PM | #5 |
Camaro- Life Member
Just had to put one on the Tahoe about 2 months ago. Was reading zero on start up. Had no ticking or knocking so I drove it across the street to parts store and changed it in the parking lot. Not that bad but still a pita. Was cold, had been 150 miles and worked that day. A short handle ratchet, short extension, wobble adapter, and the correct socket made it pretty straight forward. Just not much room on the truck engine to get at it.
Edit - Haven't looked on the Camaro to see where its at yet, or better yet, what all is in the way of it.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl 19 Tahoe 5.3 Boring Grey 91 Camaro RS 305 TBI 700R4 85 Corvette - TBD 05 Envoy 4.2 4x4 |
01-29-2017, 08:40 PM | #6 |
its in the same place as the tahoe just less room to get to it.
02-14-2017, 09:26 AM | #7 |
Ok I finally have the time to replace it so I'll doing it tomorrow and see what's up. Also replacing the gaskets. I've been told they're lifetime but idk. Cars got 82k on it is rather replace them. Thanks for the help.
03-16-2017, 03:53 PM | #8 |
Ok yeah it was the sensor pretty easy honestly, just as easy as an oil change.
04-09-2017, 02:19 PM | #9 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
went out on mine sometime last year. Was reading high all the time then one day ZERO. My friend has smaller hands. Took 15 minutes to do the job. I think it was a 27mm deep socket, 3" extension with a universal joint and rachet is all the tools needed and patience
Bone Stock |
04-10-2017, 11:08 AM | #10 |
yup its a weak link.
04-11-2017, 04:02 AM | #11 |
Drives: 13' 1LE Join Date: Apr 2012
I removed my intake more than 15x. I think I can do it in 15mins. Engine bay has been cleaned up so it is easier to work on.
So remove intake unless you have a fried with very small hands.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
Tags |
need advice, oil pressure |
