Old 12-27-2012, 05:15 PM   #1
J_Vibe92
J_Vibe92's Avatar
Drives: 2013 Mustang 5.0
Washer Reservoir Removal
Ive been searching around quite a bit and I have had no luck trying to find a DIY way to remove the washer bottle. I want to remove it cause I literally havent used it in over a year and it blocks my air intake.
Is there a link anywhere to how to fully delete it and then what do i do with all the pipes that go to it and what not?
Performance Mods: Vararam Intake, MRTv2.0 exhaust, Elite Engineering CC, Vmax Black Iceolator, Vmax Ported TB, OBX LT Headers w/ no CATS, LMR Tune
Visual mods: Eagle Eyes w/5k hids, Custom Hood Spears, Heritage Grille, Stage 2 LED Dome lights,Transformer Emblems, PD Bezels, 19in Chevy rims with pirellis, Blue painted calipers, GM GFX Front Splitter, 35/20 % Tint, TailLight Tint(charcoal)
1/4 Mile: 13.65 sec @ 102.53 mph R.I.P.
J_Vibe92 is offline   Reply With Quote
Old 12-27-2012, 05:32 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Once you pull the driver's side fender liner it is pretty straightforward. There are just a couple bolts holding it in place.
From there you just follow the hoses and undo them. To maximize air flow there is a panel behind the front bumper that needs to be trimmed and you should look at adding a scoop so that the air doesn't just go back out the bottom of the car.
Old 12-27-2012, 05:45 PM   #3
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Its pretty simple to do; it is held in with 3 13mm bolts that you can access from underneath the car (removing the wheel well would make it easier). You can disconnect the washer hose at the hood (there is a quick disconnect in the hose), then snake the hose out the rest of the way, or disconnect the hose at the pump and leave the hose in place. Then there's just the electrical connector for the pump, and that's it. I found this little write-up here.
FYI, if/when you disconnect the washer hose at the washer pump, the fluid will come out of the pump.
Feel free to call, email, or PM us anytime!
- Jeremy
JDP Tech is offline   Reply With Quote
Old 12-27-2012, 05:47 PM   #4
J_Vibe92
J_Vibe92's Avatar
Do I HAVE to remove the wheel?
Can I still trim it even though I don't got the Scoop and still get air flow
Old 12-27-2012, 05:58 PM   #5
JDP Tech
JDP Tech's Avatar
No, you don't have to remove the wheel, and don't really even have to remove the wheel well cover if you can get underneath it, just makes it a little easier.
Yes, you can definitely trim the panel without a scoop.
- Jeremy
Old 12-27-2012, 07:31 PM   #6
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I ended up jacking up the car and taking off the driver side tire, it made it really easy to remove the washer bottle.
kjkjr27 is offline   Reply With Quote
Old 12-27-2012, 07:47 PM   #7
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Not to jack this thread, but does removing the washer bottle cause any warnings on the DIC? I would guess a low washer fluid message could be a possibility?
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 12-27-2012, 08:18 PM   #8
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I don't think so
Old 12-27-2012, 08:24 PM   #9
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Originally Posted by kjkjr27 View Post
I don't think so
Correct, since there is no sensor.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 12-27-2012, 10:06 PM   #10
J_Vibe92
J_Vibe92's Avatar
Okay I'll try tomorrow. What tools do I need?
