10-25-2014, 07:52 PM | #1 |
Drives: 2010 Camaro SS Join Date: Feb 2012
Best shock/strut replacement for lowered SS
Time to make a change. Haven't seen many posts on this subject. The GM units are good but what about for a lowered car?
10-25-2014, 08:33 PM | #2 |
'It's an experiment'
1LE upgrade is what I did. I'm in the area if you want to check them out...
Here is my Suspension thread.... http://www.camaro5.com/forums/showthread.php?t=381401 -Don |
10-25-2014, 09:29 PM | #3 |
I just purchased Koni STR.T. I don't have any experience with them. I just lowered and replaced most of my suspension in the last few days. I could not find much on the topic either.
2010 SS/RS M6-LS3 -- Mods -- CAI, V-Max Throttle Body, Apex Scoop, SP 1 7/8 Headers, HF Cats, Magnaflow Tru-X.
Dyno Tuned by Mike (FAST Automotive) and Matt (FSP) BMR Suspension - Rear - Cradle Bushings (Pro Version), Upper Control Arm Bushings, Diff Bushings, Trailing Arms, Toe Rods, Drop Spring, Koni STR.T Struts. |
10-26-2014, 12:45 AM | #4 |
How is the ride quality so far?
10-26-2014, 12:47 AM | #5 | |
10-26-2014, 08:56 AM | #6 |
No problem, I did all four corners myself in about 2 hours -- its easy to do if you just replace them with stock or the 1LE -- I'm lowered also (BMR)...
-Don Last edited by hammdo; 10-28-2014 at 12:30 PM. |
10-31-2014, 08:23 AM | #7 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
I went with a set of Koni STR-T. I like them so far and they worked well on Track day.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
10-31-2014, 11:58 AM | #8 |
The Koni's are a good setup for the track, but are valved pretty aggressively for the street, so keep that in mind as ride quality will take a hit as a trade off for performance.
The best overall setup for lowering springs would be the OEM 1LE struts/shocks in my opinion; as long as you don't go much lower than 1.25" you should not have any issues. Feel free to call, PM or email me anytime with questions. Best regards, Tyler 888-308-6007 |
10-31-2014, 02:11 PM | #9 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
What kind of mileage were you guys getting from your stock shocks/struts? I just passed 56k and everything still seems fine, just not sure how much longer I should expect.
"Lowered" on ZL1 springs.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
10-31-2014, 03:05 PM | #10 |
Even on stock springs, shocks/struts should be replaced every 40-60K miles as they'll begin to lose their damping. Those with lowering springs and use their cars on track or live in an area with bumpy roads will be on the lesser end of that spectrum.
10-31-2014, 08:48 PM | #11 |
Drives: 2011 RS Join Date: Apr 2011
I added the Koni struts at 66,000. I really should have done it sooner. Driving at 70 on a smooth flat highway,the front of the car would start to rhythmically bob up and down with the slight unevenness of the road. The Konis are very firm, but really keep the car flat and smooth. I love them, but they aren't for a family car.
10-31-2014, 09:30 PM | #12 | |
Drives: '16 C7 Z51 Join Date: May 2012
Disregarding the different tech they have, I suppose they might have a shorter life since they are likely pressurized more.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
10-31-2014, 10:11 PM | #13 |
Drives: '12 ss/rs Join Date: Oct 2014
I though the z28 and zl1 have some kind of magnetic valving...so i dont think they'll work on ss cars
10-31-2014, 10:12 PM | #14 |
Drives: '14 1LE Join Date: Nov 2013
Thread Tools | |
