01-13-2017, 05:52 PM | #1 |
Drives: 2010 ssrs Join Date: Mar 2016
Need Help !
My son 98 firebirds starter spins as if you were turning key but key is off , it happens when I hook up battery so I took starter off and it stops so I ground starter and it spins again with key off , it does nothing when I try the key , the car just stopped on him last week , i change starters because the other starter was smoked , sorry if this is wrong place to post but I need help thanks
01-13-2017, 06:23 PM | #2 |
Have you checked the ignition switch? not the key and tumbler but the electronic part. Had a 96 SS that did the same thing to me. Metal contacts inside a plastic case. plastic melted and the contacts moved and engaged the starter. Damn near caught the car on fire. melted the battery terminals and cables
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
01-13-2017, 07:00 PM | #3 |
No I haven't but I will tomorrow thanks
01-13-2017, 07:03 PM | #4 |
Drives: 1996 ss camaro #1762 Join Date: Feb 2012
Also check to make sure the solenoid isn't stuck closed on the starter.
01-15-2017, 11:29 PM | #5 |
Gray Eagle
Drives: 2010 Camaro 2SS/RS IBM, 1994 Camaro Join Date: Dec 2009
Have the starter tested at a local auto parts store.
Ordered - 14 Aug 2009 Born - 4 Nov 2009 Delivered - 17 Dec 2009 |
01-17-2017, 11:15 AM | #6 |
Under a Peterbilt
Drives: Rogue, Durango and Camaro Join Date: Jul 2009
Or use the screwdriver method to test it?
Sold-2006 Pontiac GTO
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 2011 Camaro 2SS/RS M6 By Berger #11BC21 |
01-19-2017, 11:44 AM | #7 |
Drives: 1993 z28/2010 2SS Join Date: Aug 2015
yeah i had the same issue with my 93 some years back, got a starter from autozone and when i shut the car off the starter would keep spinning, had to disconnect battery for it to shut off. ended up burning my wiring a week later. stay away from re-manufactured starters for sure
