07-07-2012, 02:41 PM | #1 |
Drives: 2010 AQUA BLUE CAMARO RS Join Date: Mar 2009
New Cadillac ATS Article
Hope it translates well to the new 6th Gen Camaro. We could have us an awd & rear wheel drive 6th gen thats very light.
http://www.lsxtv.com/news/alpha-base...xt-gen-camaro/
07-07-2012, 02:44 PM | #2 |
F-body fans should get acquainted with the lightweight Alpha based ATS and it’s power train line up as it will migrate over to the next iteration of the Camaro for 2016. LS power is promised to fit the engine bay so we can expect performance versions of both the ATS and Camaro. Not only will the ATS shake up the status quo in the sports sedan segment, a 500lbs lighter Camaro will up the stakes in the retro pony car wars as well.
07-07-2012, 04:53 PM | #3 |
Shark attack!
500 pounds lighter with a v6 capable of 350 hp+ and a gen v v8 with 450-475 (if they don't lower the output) Sounds good.
07-09-2012, 01:11 AM | #4 |
Assuming it will have similar weight dimensions as the ATS, the 6th gen Camaro might not have to increase power out put much, if at all, to have noticeably better performance numbers (and they really don't have to improve the current stats by much, IMO.) However, I don't think we'll see as big of a weight drop as some are thinking or hoping for. I'll be guesstimating weight of around 3600, if any significant weight drop. We don't know enough about the 6th gen's Alpha chassis to know weight amounts for sure. It would be great to have a lighter 6th gen in the 3400lb's range, but I just don't think it be that drastic a drop.
What I'm really interested in seeing, more so than the Alpha chassis weight in the 6th gen, are the Gen V v8 engines. They really sound like the cat's meow from the little info we have so far.. |
07-09-2012, 12:28 PM | #5 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
As discussed in the other ongoing ATS thread here the current weight of the ATS with V6, MRC suspension, and Brembo breaks is 3,460 lbs. While not as light as some hope..thats still a 250 to 300 lb drop from the Camaro V6. So refering to what COPO_Chevy said about about not really needing any more power to perform much better...it is also being reported that the ATS V6 does 0 - 60 in 5.4 seconds which is somewhere around .3 to .4 of a second faster than the Camaro V6...all because of weight (ATS even has same gear ratio). Based on that, I believe we will see a base camaro in the 3,4xx range and an SS model in the 3,5xx range....maybe close to or just over 3,600 lbs but hopefully less. 500 lbs lost would utterly shock me, but man would that make for some very exciting rides even if the power levels stayed exactly the same.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
07-09-2012, 04:17 PM | #6 | |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
07-10-2012, 11:00 AM | #7 |
Drives: 21 Bronco Join Date: Jun 2012
man that ATS looks good
07-10-2012, 08:56 PM | #8 | |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2008
LS/LT 2.5L I4 $25-30K SS 3.6L V6 $35-40K ZL1 GEN-V V8 $55-60K Give or take a bit, but this is where all current indicators point to where it will end up. |
07-10-2012, 09:18 PM | #9 | |||
Drives: . Join Date: Mar 2012
07-11-2012, 12:28 AM | #10 |
That's not going to happen. Power output will not be harmed at all. That would be bad publicity. Power output will remain the same or possibly go up. Wallet output will necessarily have a much more profound increase.
