03-06-2013, 09:31 PM | #1 |
Drives: Black 2010 3.6lt v6 LT1RS 337HP Join Date: Mar 2010
Bfgoodrich g-force Rival?
Who ever gets these tires first, please sent me some feed back.
How good do they actually perform???? |
03-07-2013, 07:41 AM | #2 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
I was at the launch event at the NOLA motorsports park. We put this tire through the paces against some of its top competitors. Bottom line its the best dry handling Streetable tire I have ever tested and I have tested just about every top performing tire out there. I attached a picture of myself doing the skid pad challenge. Let me know if you have some other questions.
Here is a link to the BFG Gforce Rival on the Tire Rack website. You can click on the sizes tab to see all avaliable sizing. Last edited by Rudy@Tirerack; 03-07-2013 at 12:34 PM. |
03-07-2013, 08:15 AM | #3 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
the 315s aren't due out until May or something...I would have bought a full set other wise. May still next spring. I figure a year is all I will get out of my NT05 on the back. Unless I drive it way less that is.
-John S.
03-07-2013, 12:20 PM | #4 | |
You just made me want these tires so now I have a bunch more questions; -How many miles will they last? -Will the 285 or 315s fit stock wheels 20x9.5 rear 20x8.5 front? If not; what size will they fit? -Since I only race at the drag strip; would it be nessessary to buy the front tires as well, or am I better of with just the rears alone? |
03-07-2013, 12:45 PM | #5 |
Yeah thats me. I will post some more pictures of the event soon. You will not be disapointed with the grip.
As far as wear I have to guess as they are brand new but 15k-20k street miles would be a best estimate for now. These tires are more about smiles over miles. They are a soft compound UTQG 200. These tires also start at a lower 7.5 tread depth for less tread squirm. For autocross and track the tires wear more consistently versus any other street tire I have seen. 285's should go on 9.5 to 11 inch rim 315's should go on a 10.5 to 12.5 inch rim. |
03-07-2013, 01:22 PM | #6 | |
03-07-2013, 09:59 PM | #7 |
Oh wait a minute... You were talking about the width weren't you? Lol my mistake. I would very much like that then. Thanks
03-08-2013, 01:35 AM | #8 |
SparkyDL75
Is there any chance they will offer some additional sizes soon? I just saw this tire last week on Tire Rack and would love to do some testing with a brand new set!!!
I have 20x8.5 front and 20x10 rear wheels. I would like to run a 305/35 on the rear and a 275/40 on the front.
2010 CGM 2SS/RS M6 LS3 Black/Gray
Exterior American Racing BLVD Black w/Machined(20x10) Mickey Thompson Street Comps(275/40 & 305/35) Suspension Pedders Pace Car Pkg w/ZL1 Upgrade; Pedders Upper & Lower Control Arm, Steering, & Differential Mount Bushings; Pedders SS Brake Lines; Pedders Dual Bearing Camber Plates; ZL1 Toe Link; Hawk Performance Ceramic brake pads Drivetrain Maggie2300(8psi-3.4pulley); CompCam; 85lb injectors; ZL1 fuel pump; ZR1 MAP; Centerforce DYAD Twin Disc clutch; Stainless Works LT headers; QTP Cutouts; Rotofab intake; RX catch can; Mike Norris tune 643rwhp 598 rwtq |
03-08-2013, 01:50 AM | #9 |
ROAD COURSE JUNKIE
I like my BFG's. better than the crapellis
I had sport comp 2's PSS are an even better tire, especially for a mix of street and track use. Curious how theses rivals will do.
03-08-2013, 02:23 AM | #10 |
Drives: pleather and Chiclets Join Date: Mar 2012
what are the performance difference between the 3 rib and 4 rib treads? and whats the range of squeel to completly slipping and out of control? is it instant like a slick or more manageable for a hobbiest?
03-08-2013, 09:21 AM | #11 | ||
03-08-2013, 03:51 PM | #12 | |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Will see if they live up to the hype....
03-08-2013, 06:46 PM | #13 |
tire rack...no veterans discounts no answering of questions... i wanted to buy these tires from you but good god do a little work for my money.............
03-09-2013, 05:07 PM | #14 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Yep yep waiting till the p-zeros die on the autoX of wheels than I will be hitting up a set of 285/35's should be grippy
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
