07-23-2013, 10:19 PM | #1 |
Drives: 2006 Z06 Join Date: Sep 2010
2010 SS vs 2008 Z06
so given the same driver: How much hp do I need to run down a 2008 Z06(505hp crank) at the drag strip? I think the Z's have just as much problem with wheel hop as we do.....what do you guys think?
His Z is stock with only and intake and axle back exhaust. He won't mod anymore because he doesn't want to blow and exhaust valve or void the warranty....what's it take to beat him? 475whp? 500? more? |
07-23-2013, 10:56 PM | #2 |
Drives: C6 Z06 Join Date: Jan 2010
lol a great driver behind that car with perfect air can run very low 11's
07-23-2013, 11:10 PM | #3 |
I realize this.....with drags they can be really fast really quickly. I am asking how much hp do I need to match him....estimated?
07-23-2013, 11:25 PM | #4 |
Drives: '11 Cammed LS3, '14 Scion FRS Join Date: Dec 2011
Some badass ran a 10.98 bone stock in his.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP |
07-23-2013, 11:39 PM | #5 |
07-23-2013, 11:54 PM | #6 |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
Assuming you have a LS3.....a good cam, headers, catback, CAI, and a tune will give you sufficient power to POSSIBLY compete with a C6 Z06. You'll need shorter height rear wheels/tires (preferably DR with 18" wheels) and aftermarket trailing arms to be able to cut a good 60 ft. The most difficult task for you will be to get a perfect launch off the line.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
07-24-2013, 12:10 AM | #7 |
Drives: 12 MP4-12C, 16 Quattroporte Join Date: Mar 2012
What tires is he running? What about you? At those power levels tires are as important as anything.
07-24-2013, 12:42 AM | #8 |
right now I just have the stock 20s. The car is going under the knife soon. installing a 231/239ish cam, cats and arh headers. only mods right now are corsa exhaust and cai intake-looking for 470 at the wheels hopefully.
07-24-2013, 12:43 AM | #9 |
he's on stock tires...
07-24-2013, 01:40 AM | #10 |
Have not lined up with one on a drag strip. But at the air strip (Unprepared surface)with my stock tires a stock 427 Z06 made my Camaro look slow for a good bit. It took ALL 624rwhp from my LS3 with a V3 to run him down.
Keep in mind as the speed goes up that Z06 has a huge Aerodynamic advantage. So it takes even more power to keep up lol. If he ever decides to heads and cam that motor look out! |
07-24-2013, 10:31 AM | #11 |
Thankfully I think he will be stock for a long time due to the exhaust valves that have been destroying motors....without a warranty some guys have run into a 15k new motor bill to get their cars back on the road.
07-24-2013, 10:32 AM | #12 | |
07-24-2013, 07:42 PM | #13 |
"Go on the last yellow.."
Drives: 2010 2SS/RS L99 CGM Join Date: Jan 2010
Check out wannagofast.com. Clayton,GA. in September!!
Blown and built by Ty Sochacki, tuned by Jeremy Formato. Member of the 11 second club.
07-24-2013, 08:44 PM | #14 |
5.0 lol...
Drives: 2010 Camaro 2SS M6 Join Date: Aug 2012
I used to have a cam/bolt on ls3 that was damn near 500whp. Would it have beaten a Z06 (with a competent driver) on the track? Nope. Your hope is for him to not be the best driver, then you'll get him
2010 2SS M6 SWG built turbo car
2000 Z28 A4 Custom tuned by a Skinny White Guy |
