10-27-2009, 05:58 PM | #1 |
ARH 1 3/4 or 1 7/8 cats or no cats??
I've decided to order LTs for my camaro and I've settled on ARH.
1 3/4 or 1 7/8??cats or no cats?? wich one make more TQ /HP I did a search and no clear answer? the plan is going to be LT's ,CAI and stage 1or 2 cam for now P.s mine is LS3 Thanks
recieved 7-10-09 2010 camaro black 2ss/RS/6m
10-27-2009, 06:03 PM | #2 |
Drives: 05 Cadillac CTSV, 97 Camaro SS Join Date: Jun 2009
Get the 1 7/8 with cats... 1 3/4 is a good size to get if you plan on sticking with bolt ons, but the 1 7/8 will be better suited for future mods.
And cats will help keep the car smelling clean after you get a cam... no cats on a cammed car will usually cause a raw fuel smell at idle since larger cams don't efficiently burn all the fuel at idle. |
10-27-2009, 07:32 PM | #3 |
Drives: SIM RS/SS L99 Join Date: Sep 2009
Is there a significant difference in sound b/t cats and no cats?
10-27-2009, 07:33 PM | #4 |
Drives: 2010 Camaro Auto 2SS/RS Join Date: Oct 2008
Go with where you want the power band to be. 1 3/4 gives you more torque throughout the entire rpm range and more hp down low. 1 7/8 will give you more hp up top. It's important to say you will gain tq and hp with either of these, it's just up to you where you want the most power. For just driving around the street I'd go with 1 3/4. If you are gonna track the car a lot and spend a lot of time in the upper rpm range go with 1 7/8.
10-28-2009, 07:31 AM | #5 |
Drives: holden commodore Join Date: Jul 2008
Simply if you want to get a cam get the 1 7/8 but if you stick with boltons have the 1 3/4 , either way the offroad pipes"catless" is the best .
10-28-2009, 08:08 PM | #6 |
Drives: 99 camaro Join Date: Sep 2009
definetly catless is louder and makes around 10 hp
Soon to own: 1SS CGM M6
10-28-2009, 08:11 PM | #7 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
I would use the 1 7/8 system with cats. You will maintain reliability, sound great, make power, and you will have room to build more power with future mods.
10-29-2009, 06:04 AM | #8 |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
If im not mistaking a System from ARH comes with this piece for a Catted System am I correct ?
The offroad system does is consist of the same stuff just a different piece of pipe meaning one with the same bends just no cats ? OR does it come with a totally different set piece of pipe with no cats and a different Xpipe ? |
10-29-2009, 08:08 AM | #9 |
I believe it come with teh same pipes but no cats...
Thos epipes are bent that way for clearance, so I do not think that would change. |
10-29-2009, 11:02 AM | #10 |
if ur state does emission check u need cats..
if not then dont get cats save the money...
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
10-29-2009, 11:11 AM | #11 |
GQ I have the 1 7/8 ARH system currently with Cat im going to purchase the offroad connection pipes and install those and when its time to get it inspected put the Cats on.
Surely it cant be hard to switch them out. |
10-29-2009, 11:24 AM | #12 |
no not hard at all to switch them out.. sounds good..
where i was in TX.. killeen there was no emission check
10-29-2009, 12:17 PM | #13 |
Drives: Pontiac G8 GT Join Date: May 2009
Guys, If your Camaro is LS3 powered, 1-7/8" is where you need to be. We've done the back to back testing (same day, same car, same dyno) and the LS3 wants 1-7/8" headers. After 2 hours on the dyno we could not get the 1-3/4" headers within 10 RWHP of the 1-7/8". These results do not apply to L99 equipped Camaro's.
Nick |
10-29-2009, 01:00 PM | #14 | |
480 HP 2010 2SS
Without data you are just another person with an opinion.
1100 :10/15/08 3000:3/2609 3300:4/18/09 3400 (broadcast)April 25, 2009 3800 (produced):May 4, 2009 #7470 4200 (Shipped): June 1, 2009 5000 (At Dealer) June 9,2009 374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg. |
Similar Threads | ||||
Headers for an L99 Automatic.....17/8 or 1 3/4 ? | Jekyll-N-Hyde | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 34 | 08-02-2010 01:54 PM |
What size headers should I get...? 1 3/4, 1 7/8 or 2" | Carlos Garza | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 10-12-2009 09:24 PM |
ARH only to the cats? | RickyTheStorm | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 09-19-2009 08:38 PM |
Request: L99 w/ ARH LT Headers w/ high flow cats and SLP LM (1 or 2) Exhaust | StlRomAniaN | 5th Gen Camaro SS LS LT General Discussions | 2 | 08-28-2009 09:08 AM |
