04-19-2014, 02:52 AM | #1 |
Drives: 2011 LS3 Join Date: Jan 2012
ls3 ticking noise. Help!!!
Ive got an ls3 with 30k it just started making a tick/flapping noise recently. I ve replaced header gaskets and re tightened all my exhaust system. It specifically makes this noise between 1500 to 2800 rpm approximately. It quites down a lil bit after a few minutes but it's still present. Any suggestions??? I ve heard a few videos on YouTube and those don't really sound like what my car is doing.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
04-19-2014, 06:14 AM | #2 |
Could be in your valve train. If you still have warranty I would take it in.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
04-19-2014, 08:37 AM | #3 |
Im tuned so my warranty is gone. Plus ill be getting cammed soon. I also use Pennzoil platinum and change regularly.
04-19-2014, 09:19 AM | #4 |
old school chevy rodder
I also would look to the lifters ticking .....but who knows........
04-19-2014, 09:22 AM | #5 |
What's the best method to diagnose this without taking off the valve covers?
04-19-2014, 09:27 AM | #6 |
Another thing also if I open the hood and listen and rev it to those rpm you really can't hear anything other than normal valve train noise. It more noticeable from in the cabin while driving at low speed between 1500/2800 rpm.
04-19-2014, 09:36 AM | #7 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
My past L99 sounded like a sewing machine under the hook when it developed lifter issues. Headers can also sound like this. When did you install your headers.
04-19-2014, 09:39 AM | #8 |
About 10k ago never heard anything till recently.
04-19-2014, 10:47 AM | #9 | |
Too much is never enough!
just because you tuned it doesn't necessarily mean you voided your power train warranty...its worth a shot to take it in anyway
04-19-2014, 12:02 PM | #10 | |
Op.... sounds like it's time for you to get a cam and replace all the internals. Lol.
04-19-2014, 01:01 PM | #11 |
Drives: 2014 Camaro SS Join Date: Sep 2013
All LS motors, from my experience, are going to be making noise. The injectors are pretty loud, and also the valve train gets louder the more miles you put on it. I've had several different LS motors and they've all done it. I've had an LS1, LS2 and now the LS3 and they have all made some type of valve train noise.
I've learned to deal with it and live on knowing that as long as my car doesn't blow up, I'm going to be fine. |
04-19-2014, 01:16 PM | #12 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
04-19-2014, 04:14 PM | #13 |
Thanks for the help guys. Guess ill just wait and see if theres anything going on once they open it up for the cam.
04-19-2014, 04:58 PM | #14 |
Drives: Black aSS 2011 - L99 Join Date: Apr 2012
First of all its a Chevy so its going to "tick" when its cold. Like the childhood joke goes......Can Hear Every Valve Rod Or Lifter Every Time. C-H-E-V-R-O-L-E-T! Its doing what it is supposed to do, The autos with VVT don't d this but you had to have the stick. Live with it.
Staying stock and loving it............
