05-27-2015, 11:18 AM | #1 | |
LS7 Camaro6?
Speculation of course...
http://wot.motortrend.com/1505_cadil...ls7_power.html http://www.motorauthority.com/news/1...-liter-ls7-v-8 Quote:
05-27-2015, 11:21 AM | #2 | |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
A Gen 6 Camaro with the LS7 for under $50K is NEVER going to happen. It would be nice though.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
05-27-2015, 11:33 AM | #3 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
My understanding is the LS7 emissions cert ends soon. They won't be able to put it in emissions controlled vehicles. I guess they could have extended it but I don't see why they would. The LTx has the capability to at least match the LS7 without 7.0 liters.
05-27-2015, 12:02 PM | #4 |
Drives: Four wheels and an engine Join Date: Sep 2014
LS series of engines are going the way of the Do-Do for production cars.
05-27-2015, 12:06 PM | #5 |
Drives: 66 Chevelle SS Join Date: Mar 2013
Who wants to match it? Improve it is a smarter idea. Anyone who thinks 505 horses is the end of the N/A emissions compliable spectrum is likely wrong. Key would be a much higher redline which is doable. GM has dropped their warranty to 60k miles for 2016 anyway.
05-27-2015, 12:09 PM | #6 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
DI ls7 with improved heads/cam/ intake should be good for ~550 hp. LT7. Gt350 answer. It would be awesome.
05-27-2015, 12:13 PM | #7 |
C'mon- really?
I've been thinking the exact same thing, maybe even in the higher 500HP range. And it should be a lot less expensive than the LS7.
Steve
05-27-2015, 12:17 PM | #8 |
Drives: 2023 SGM Camaro 2SS 1LE 6M Join Date: Apr 2009
There isn't any more development of performance Gen IV V8's being done at GM.
05-27-2015, 12:20 PM | #9 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
LT5.
32 valve small block v8, just like the original one in the ZR1. They made 405hp then with a 475hp version that was almost ready for production. That would easily make 540-550hp as a 6.2 and todays tech. Would run the Gt350's face through the mud just like the SS will be doing to the GT. |
05-27-2015, 12:20 PM | #10 |
GM was working on such an engine for the Z06. It was shelved in favor of the LT4 because it couldn't hit emission requirements at the desired power levels.
05-27-2015, 12:22 PM | #11 |
Note the MT article has no source or meaningful information and the other is quoting the MT article, just pure speculation. Why mess with converting a LS7 to DI when you could simply increase the displacement slightly on the LT1 and hit the same power goal. I think the rejected NA engine for the ZO6 is more likely than continued LS7 production.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
05-27-2015, 12:33 PM | #12 |
Drives: 2005 Cobalt Base - 5 speed Join Date: Apr 2015
"At the desired power levels." Now if they were trying to hit 600+ for the Z06 and it wasn't happening, ok, but they could probably use that same engine at 550 or 575 and meet emissions, wouldn't you think?
05-27-2015, 12:36 PM | #13 |
Doesn't DI improve emissions ? Better heads and other parts shouldn't hurt either.
And this motor has had 505 hp since 2006. I would think an extra ~50 hp could be done pretty easy. It's the perfect choice imo. |
05-27-2015, 12:37 PM | #14 |
I'd think so. I really need to go dig up those quotes and interviews to read how it was worded again.
