11-01-2011, 09:46 PM | #1 |
Drives: 2010 IBM Camaro SS Join Date: Jun 2007
X-pipe added to L99
I had an x-pipe installed today and had a chance to drive around a while (both cith and highway). I'm not hearing any 'drone' or other unusual sounds related to removing the resonator. The car actually sounds quite a bit better, especially when accelerating. I also noticed that the rattling of the heatshield when I rev the engine doesnt seem to happen anymore (though I dont know why removing the resonator would do that).
I can hear/feel the AFM activating but it sounds the same now as it did before when the only mod I had done to exhaust was the high flow cats.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
11-01-2011, 09:50 PM | #2 |
I'd rather be shooting...
Drives: 2010 2SS/RS Black/Black Join Date: Dec 2009
I recently had a corsa cat-back put on. Sounds so good until the AFM kicks in.
Follow Us on
The Official Photographer of the 2010, 2011 & 2012 Camaro5 Fests!!! www.theshuttergroup.com |
11-01-2011, 11:29 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Drone isn't taken care of in the X pipe or the resonators. It's canceled out in the J tube, inside the OEM muffler.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
11-02-2011, 08:46 AM | #4 |
An X-pipe is a nice upgrade. Did you keep the stock mufflers?
11-02-2011, 01:53 PM | #5 |
Yeah, still stock mufflers. The cats and x-pipe are the only thing I have changed on exhaust so far.
11-02-2011, 07:03 PM | #6 |
Anyway of getting a video posted? I've been contemplating headers all the way back but considering HF cats and x pipe to start then come back with headers at a later date.
11-03-2011, 11:21 AM | #7 |
I can try. I dont have a good video camera though, so may not have good sound.
11-08-2011, 01:52 PM | #8 |
11-08-2011, 03:13 PM | #9 |
Ouch, that sounds like you have bad lifters BAD. That is what that ticking is that did not go away within 10-15 seconds.
11-08-2011, 03:20 PM | #10 |
It sounds just like a couple other SS w/ L99 I test drove, and the dealership(s) I asked also said its normal. ALso, anything you're hearing there is just exhaust and echoing in the garage. THe lifter 'tick' is very faint in actuality and cant be heard on that recording.
11-08-2011, 03:23 PM | #11 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
What's the purpose of the x pipe? Just sound?
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
11-08-2011, 03:30 PM | #12 |
It is used to do what is called cylinder scavenging. When the exhuast flows across each other in the pipe they help pull the exhaust faster out of the engine and increases low end torque and hp.
11-08-2011, 03:50 PM | #13 |
I thought that the factory exhaust made the most hp and no one was finding more power out of aftermarket exhaust?
11-08-2011, 04:05 PM | #14 |
Factory Mufflers are fine, but if you upgrade parts like the Cats you get more power. I dont know for sure if x-pipe adds power but it could potentially do so. Also , it does sound better for sure.
Similar Threads | ||||
More boost "allowed" on L99? | general23cmp | Forced Induction - V8 | 9 | 09-11-2010 10:03 PM |
FS - Corsa XO Pipe only - L99 version | duffmobile | Local Marketplace | 0 | 08-06-2010 02:50 PM |
Exhaust Theory revisited | Wacker | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 11-23-2009 10:12 AM |
X pipe on L99 | Kodiak Ak | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 10-21-2009 02:39 PM |
L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 11:40 AM |
