Old 07-13-2016, 10:57 AM   #1
cj04
cj04's Avatar
Drives: 2010 2ss/rs
New Clutch
I have a 10 SS, throwout bearing blew out on me. My question is, which clutch should I go with? After seeing the price on some of these kits i'm considering just going stock. Are there any after market upgraded clutches that can use the stock flywheel? Any help would be appreciated. I currently only have bolt-on's.
cj04 is offline   Reply With Quote
Old 07-14-2016, 11:30 AM   #2
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
I'm sure someone will chime in on aftermarket. However if you go stock there is a billet bearing support, made from aluminum, to replace stock plastic piece which is probably what failed in the first place.
http://monsterclutches.com/gen-5-cam...earing-support
http://monsterclutches.com/billet-bearing-install
http://www.camaro5.com/forums/showthread.php?t=400884
keith.wilkinson.10 is offline   Reply With Quote
Old 07-15-2016, 04:12 PM   #3
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
Aftermarket or stock clutch, your decision. I definitely recommend the monster billet bearing support and a remote bleeder. As far as clutches, well I upgraded to a monster twin when my throwout bearing also went. So far so good.
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 07-26-2016, 01:51 PM   #4
Centerforce_Clutches
Centerforce_Clutches's Avatar
Drives: Chevy Camaro
If you have light bolt-ons and dont do much performance/track driving, a stock clutch is usually the best option.
Centerforce_Clutches is offline   Reply With Quote
Old 07-26-2016, 06:07 PM   #5
Bo White
Bo White's Avatar
Aftermarket all the way.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 07-27-2016, 07:08 AM   #6
cj04
cj04's Avatar
Drives: 2010 2ss/rs
I went with a centerforce clutch and flywheel. Also got the release bearing support. Thanks everyone.
Old 07-28-2016, 08:22 AM   #7
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
The guys at JDP recommend the ZR1 setup. There's an adapter or something that JDP came up with to make it work better. Supposedly stock demeanor but can hold a massive amount of power. It'll be my set up when the time comes. I agree on the throw out bearing and also the bleeder hose isn't a bad idea either.
Firefighter is offline   Reply With Quote
Old 07-29-2016, 12:54 PM   #8
Great! Please let us know how you like it once everything is installed!
