08-31-2016, 10:24 AM | #1 |
Drives: 2011 2LT RS Victory Red Join Date: Oct 2015
Routine Fluid Changes
Hi Guys & Girls,
I just got back from my local Chevrolet Dealer after having my oil changed on my 2011 Camaro with 15,127 miles on it. My service writer suggested that after 5 years ( even with low miles ) I should start replacing some of the fluids. I do nothing mechanical, so I pay to have everything done. This is what she suggested. (1) Transmission Flush $260.00. (2) Coolant Flush $180.00. (3) Rear Differential Fluid Change $165.00. (4) Power Steering Fluid Change $125.95. (5) Have the injectors Cleaned $199.95. My question is that do you agree with her, and if you do, in what order would you do them? Thank you for your help. Rich |
08-31-2016, 10:32 AM | #2 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
$165 for the rear diff??? Holy smokes. Took me like 20 mins and the fluid (forget the total cost but it was less than $50).
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
08-31-2016, 10:32 AM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I agree with all but the power steering and injector cleaning. If you don't have a catch-can on the car, then doing an upper valve cleaning would be worth it over injectors being cleaned.
Diff fluid is one of the easiest to do yourself, if you were going to try to save some money. I honestly am doing my diff and trans fluid every spring BECAUSE it's so easy to do that it is worth it for the peace of mind. I'm also surprised that brake fluid isn't on there. That stuff collects moisture through the air and should also be swapped roughly every 3 years.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
09-01-2016, 02:21 PM | #4 |
376 cubic inches of fun
No, I don't agree.
Transmission: No Coolant: No Power Steering Fluid: No (probably never) Differential: No (probably never for an open diff) Injector Cleaning: No (never, unless you have a performance problem) I would take a look at the maintenance schedule in your owner's manual. Unless you race or drive a lot in very high heat (and I see you in CT not Texas) you can safely follow the normal maintenance schedule. With your low miles, I bet the first thing you will need to replace is the battery. |
09-01-2016, 04:39 PM | #5 |
Drives: 2014 1LT w/RS Summit White Join Date: Aug 2015
I agree with all but the power steering and Injector cleaning.
09-01-2016, 05:16 PM | #6 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
coolant flush and rear diff but at half those prices posted. the others, nah. yes to a brake fluid flush.
09-01-2016, 09:49 PM | #7 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Was she at least pretty?
So grab some tools, hand cleaner and have sum fun! lol....F. Weller
09-01-2016, 10:44 PM | #8 | |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
09-02-2016, 02:08 AM | #9 |
USA-1
Coolant flush definitely. Differential fluid costs $11.79 for the one quart you'll need. Spend another 5 or so for the friction modifier and you are at $17 out the door. If you are okay on spending $165 for that, by all means knock your socks off. :P
09-02-2016, 08:34 AM | #10 | |
Drives: Camaro Justice Join Date: Jun 2007
(2) Coolant Flush $180.00. Do it. (3) Rear Differential Fluid Change $165.00. Pass (4) Power Steering Fluid Change $125.95. I have seen some issues with the seals in the rack and pumps on the V8s. I would change the fluid and ask them to use the current version of Dexron ATF. (5) Have the injectors Cleaned $199.95. Pass (6) Flush the brake fluid and replace with stock fluid. |
09-02-2016, 08:42 AM | #11 | |
PC too much!?
lighten up! seriously EVERYBODY has a view and RESPECT is being ADULT enough to accept that fact... guess you don't have any hand cleaner either huh? (sarcasm in case you missed that...lol) F. Weller P.S. And I SIGN my comments...
09-02-2016, 05:52 PM | #12 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Honestly I don't change coolant unless I'm doing a service that requires draining it, or if it became contaminated. I'm sure you'll be fine without pretty much any of the services
09-02-2016, 05:53 PM | #13 | |
SHKE BKE
And only because it's DI I work and have worked at other shops, any good tech would laugh at the recommendations they are making. They just want some dough |
09-02-2016, 05:59 PM | #14 | |
So maybe get those done after seven years or so. As for the diff, I think the OP has an open diff. I can tell you from experience that the oil in an open diff looks and smells like new after even 100,000 miles. |
