05-19-2014, 09:46 AM | #1 |
XLR8TNG
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Supercharger coolant check.
Just pulling my car out of storage and was wondering how often do I need to be checking the supercharger coolant? When you twist the fitting and remove the cap should coolant be visable? (Cold unstarted motor). Have not done anything yet but want to go over the car before I start driving her this season.
05-19-2014, 09:53 AM | #2 | |
This should be treated like any other fluid level and checked at every oil change interval or before any track event. We have found several cars with low coolant levels, when the coolant level gets low the pump won't run causing very high IAT and low performance. The computer protects the engine through IAT 2 sensor and pulling all the timing. Any time the system has been opened/Drained, it should be Vacuum bleed of air. If the pump senses no load/AIR the pump will cease to run to protect it self from burning out. So if you change a part in the system i.e heat exchanger, coolant reservoir, pump upgrade, it is imperative that proper fill procedures are done. Ted.
www.jannettyracing.com
05-19-2014, 10:35 AM | #3 | |
XLR8TNG
05-19-2014, 10:38 AM | #4 | |
Ted.
05-19-2014, 10:41 AM | #5 |
XLR8TNG
05-19-2014, 11:10 AM | #6 |
Drives: '21 ZLE A10 Join Date: May 2012
just get a reservoir and this procedure is simple.
05-19-2014, 01:06 PM | #7 |
XLR8TNG
Hey Ted. How do you remove the cap? I turned the fitting to the upright position and turned cap counter clockwise. It will not remove. Bit confused.
05-19-2014, 01:23 PM | #8 |
Drives: none Join Date: Aug 2011
If you turn it to the right spot, you'll see the clip that holds it on expand. Then pull the cap off. Easy.
05-19-2014, 01:28 PM | #9 |
It should be filled with Dexcool? Is this done when cold and the engine off?
Edit, I topped it off it was a bit low after dealer replacement of the supercharger. Last edited by ZL1-V; 05-19-2014 at 02:13 PM. |
05-19-2014, 02:39 PM | #10 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
The coolant level should be at the bottom of the goose neck (which is still visible) if that makes sense.
Edit: to the bottom of the filler cap. Last edited by DrkPhx; 05-19-2014 at 02:58 PM. |
05-19-2014, 04:08 PM | #11 |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
Where do you check the coolant level of the s/c?
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
05-19-2014, 06:14 PM | #12 |
The upper hose attached to the front of the supercharger lid is where the filler neck is located. It's usually turned sideways. Just turn it right side up, remove the purple clip to take the cap off and boom.. there it is.
05-19-2014, 07:09 PM | #13 |
ROCK
THANKS FOR THE INFO! !!
05-19-2014, 07:12 PM | #14 |
XLR8TNG
Got the cap off and she was looking good! Dex-cool was right at the bottom of the cap. I did call Janetty racing to ask the proper way to remove the cap. Once Nick explained that when you twist the cap look for the snap ring to expand then stop turning and gently pull up. His advice worked like a charm and he was very nice to speak to! Great helpful and polite staff you have Ted!
