03-18-2015, 12:59 AM | #1 |
no lift shifting
So.... Just playing around in my car I've noticed that when using launch control I can No Lift shift my car.
Its a 2014ss
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
03-18-2015, 02:40 AM | #2 |
Drives: '14 Red 2SS/RS/LS3 Join Date: Dec 2013
I was SO nervous the first time I used Launch Control on my car. It's so anti-intuitive to push in the clutch, then PIN THE ACCELERATOR PEDAL! I haven't read anything about our cars having the "no lift" shift feature, but if so, cool!
2014 Red Hot 2SS/RS/M6/NPP/Shifter/Nav/Roof/SilverRallyStripes/Airaid intake/GM StrutTowerBrace/50%-35%tint
03-18-2015, 02:51 AM | #3 |
Well my tuner added launch control on my car. Before if you pushed in the clutch it would rev to redline. Now it sits nicely at 3500rpm. Our local drag strip opens this weekend so I'm going to try and beat my 12.9sec 113mph time. Before I had no launch control nor did I have stickies on the back. These nitto 305s should hook.
03-18-2015, 03:08 AM | #4 | |
03-18-2015, 06:45 AM | #5 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
03-18-2015, 07:36 AM | #6 | |
Drives: 2014 Summit White 2SS/RS M6 Join Date: Aug 2012
ok, let me get this straight, if we do what the guy in the video does with his ZL1, i dont have to let go the gas pedal when WOT?
03-18-2015, 08:04 AM | #7 |
My 2010 has launch control. It revved to 4500 rpm. Since i got the car tuned it no longer has it.
03-18-2015, 08:31 AM | #8 |
Drives: 2014 2SS RS LS3 Join Date: Oct 2012
Correct me if I'm wrong, but isn't No-Lift Shifting only on the ZL1? Isn't the point of it to build/avoid losing boost while shifting? What advantages would us N/A V8's get from no lift shifting?
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS |
03-18-2015, 08:37 AM | #9 |
Drives: 2015 Camaro SS 1LE Join Date: Dec 2014
I added no lift shifting to my tune.
I think we're talking about two different subjects here. Launch control and no lift shifting. |
03-18-2015, 08:42 AM | #10 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
I have the launch control on my 2010 2SS but don't have the dry option. It just goes into launch control and holds the revs at about 4500. Don't know about the no lift shifting as I have never tracked the car. Cool feature though.
USMC 1980-1990
My other toys are Harleys |
03-18-2015, 08:50 AM | #11 |
Non-ZL1 SS Camaros have Launch Control, but do not have the No-Lift Shift feature. It can easily be done, but if you could have a money shift if not careful.
03-18-2015, 08:58 AM | #12 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
My understanding is it maintains boost between shifts.
Automatics need not apply...not a concern there. For everyone else who doesn't have turbos or a supercharger, it's called good 'ole power shifting, and you don't need a feature programmed into the car to do it. Launch control is a separate feature, although the two features might activate together. Launch control manages the application of maximum power from a complete stop to minimize wheel spin. You also don't need this to launch a car appropriately, but it's a great feature to prevent noobs from completely destroying a perfectly good clutch. |
Thread Tools | |
