03-18-2015, 01:58 PM | #1 |
Commanded Lambda
Is a Commanded Lambda > 1.0 commanding more fuel or more air?
03-18-2015, 02:30 PM | #2 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
< 1.0 is more fuel than air, > 1.0 is less fuel than air
03-18-2015, 02:36 PM | #3 |
03-18-2015, 03:18 PM | #4 |
Yes, but unless it is in deceleration or power enrichment mode it should be 1.0.
03-19-2015, 06:03 AM | #5 |
In lambda, less than 1 is richer than stoich, and higher is leaner. In EQ ratio, higher than 1 is richer than stoich, and less than, is leaner.
03-23-2015, 06:23 AM | #6 | |
So a Commanded Lambda >1will result in a -STFT (negative take fuel away) and Commanded Lambda < 1 will result in a (positive add fuel) STFT Last edited by camguynj; 03-23-2015 at 08:43 AM. |
03-23-2015, 10:27 AM | #7 |
Geek
Trims don't have anything to do with commanded lambda. Trims are determined completely by the front O2 sensors in closed loop. If commanded lambda is anything other than 1.0, then narrowband fuel trims are useless.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
03-23-2015, 06:04 PM | #8 | |
http://info.efidynotuning.com/fuel101.htm Note these highlights... Lambse is a derivative of LAMBDA or the "AFR" (air/fuel ratio) the ecu is demanding" . STFT = Lambse Short Term Fuel Trim is the lambse difference from stoich (1.000 - lambse) * 100 , It is the exact same representation of Lambse. To put this into perspective, lets say at WOT we have a LAMBSE of 0.800 1.000 - 0.800 = 0.2 * 100 = 20 (STFT) Now, lets say we have a negative STFT value of -18 1.000 - (-18 / 100) = 1.18 LAMBSE as you can infer, a negative STFT means its removing fuel, so lambse will be greater than 1.000 (leaner) a positive STFT means it is adding fuel, so lambse is less than 1.000 (richer)" |
03-24-2015, 08:37 AM | #9 |
Geek
Ok. I'm not sure what you're trying to get at here. STFT is still only useful if commanded lambda is 1.0.
03-24-2015, 11:26 AM | #10 | |
So when Commanded Lambda/Lambse is: 1.0 (STFT=0) no fuel change <1.0 (STFT is +) add fuel >1 .0 (STFT is -) remove fuel |
03-24-2015, 04:22 PM | #11 |
Geek
No that is not how it works.
Commanded lambda is not used to determine fuel trims. If STFTs are active, then commanded lambda is 1.0. Period. Maybe you're confusing commanded lambda with actual lambda? They are two different things. STFT of +10% would imply that your actual lambda was 1.10 while your commanded lambda is 1.0. All the STFT is doing though is bringing actual lambda back to 1.0.
03-24-2015, 04:30 PM | #12 | |
03-25-2015, 08:37 AM | #13 |
Geek
Ok I had to go back and look at some logs to see when mine showed STFT values. Sometimes they don't make sense.. as in the values are there, but are not affecting fueling according to my wideband.
The ECM will command a richer lambda on startup and actual closed loop is on a 10 second delay when startup coolant temp is between 40* and 241*. Once that 10 seconds passes commanded lambda ramps up to 1.000 and fueling swings with the O2 sensor voltages as expected. Driving around I never see an EQ ratio other than 1.0 unless I go into power enrichment. When do you see commanded lambda at values other than 1.0?
03-25-2015, 09:40 AM | #14 | |
