06-10-2010, 06:28 PM | #1 |
GM Toyz Lover
Drives: GM Toyz Join Date: Oct 2008
Removing power steering pulley
Has anyone ever removed their power steering pulley? Does it require a special tool?
Thanks
Angela
06-10-2010, 11:20 PM | #2 |
Madman
unsure about ls3/l99..but I know older Gms had a lil tool to remove PS pump pulleys.
Rick |
06-11-2010, 12:12 AM | #3 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
are you planning on pulling the pump as well?
There is a pully removal/install tool that you can rent/buy to get the pulley off. or IIRC, you can use a 13 mm to loosen the two bolts behind the pulley till you can work the pump forward enough to fit a 15mm wrench in to pull the rest of the bolts
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
06-12-2010, 08:50 PM | #4 |
Drives: 2010 2SS/RS A6 Join Date: Feb 2010
I used a standard power steering pump pulley removal tool for GM and it work fine. The Pulley has a groove much like the older style power steering pump pulleys.
06-12-2010, 09:53 PM | #5 |
Madman
yea,can rent it from any Autozone
06-13-2010, 08:58 AM | #6 |
Drives: A wrench Join Date: Jan 2010
Yes, you'll need a tool kit similar to this to remove/reinstall it...
Similar Threads | ||||
DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 08:25 PM |
Power Steering | JohnZ | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 05-05-2010 11:55 PM |
Calling Shorty Header Owners | Inferno2SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 87 | 04-05-2010 01:59 AM |
I need help I was doing donuts and now I have no power steering | Vinnysrt8 | 5th Gen Camaro SS LS LT General Discussions | 150 | 11-14-2009 10:18 PM |
Power Steering - hydraulic or electronic steering? | balonywolf | 5th Gen Camaro SS LS LT General Discussions | 20 | 02-28-2008 11:01 PM |
