07-26-2015, 03:08 PM | #1 |
Drives: Cammed 2010 SS Join Date: Jun 2013
Forgestar 20x12???
So I found a set of Forgestar CF10's and they are 20x9 +16.25 in the front and 20x12 +40.5 in the rear. They came off a CTS V. Don't know much about offsets and I did I a search but couldn't find anything on this, so I come here to ask you guys would these fit by any chance? Or would I need spacers or something? Thanks!
2010 Camaro 2SS/RS LS3 - 450rwhp and 425tq
- TSP 231/236 Cam, Dynatech 1 7/8" LT Headers, Dynatech Cat Delete, CAI Intake, BMR 1.4" Drop Springs, Hurst Short Throw Shifter, Magnaflow Street Series Axle-Back w/X-pipe - Tuned by Ivan @ SouthwestSpeed |
07-26-2015, 05:36 PM | #2 |
They will be way out from the OEM
The rears will be just about 1"1/2 further out from the OEM , since the offset is almost the some 40mm vs 40,5 mm The fronts will be 1/2" plus about 3/4" ( from the difference on the offset 35mm to 16,25mm ) this will compound to 1"1/4 from where the OEM wheels are positioned |
07-26-2015, 06:38 PM | #3 |
Drives: 77corvette/2011blkcamaro Join Date: Oct 2009
I feel your angciaty please let us know if they fit thanks brother
07-26-2015, 10:51 PM | #4 |
The front wheels will still not stick out quite as far as the ZL1/1LE wheels. In reference to the stock SS wheel the inside edge of the rim would move out towards the fender 6mm and the outside edge 32mm. The ZL1/1LE wheels are 37mm farther out versus the SS rims. The rear wheels would take up 37mm more clearance inside and 37mm more outside.
07-27-2015, 09:51 PM | #5 |
So what I'm getting out of this is there is a good chance that they will fit?
07-28-2015, 08:42 AM | #6 |
Drives: 2011 2SS/RS Join Date: Feb 2014
Rears would probably fit OK. Fronts will likely not
