10-06-2015, 08:11 AM | #1 |
Drives: 2011 Camaro 1SS Join Date: Dec 2011
Which fuel pump?
I have a cammed bolt on l99 and I'd like to add a 150 wet shot. How do I determine which fuel pump would flow adequately for that setup?
Thank you |
10-06-2015, 09:20 AM | #2 |
Drives: 2010 SS Join Date: Jun 2015
Stock is just fine for a 150 shot as long as you have the upgraded feed line for the fuel rail.. Either the nitrous outlet kit or the flipped rail with the c6 line.
10-06-2015, 09:42 AM | #3 |
What power level would I be around for 430 whp+ 150 shot?
10-06-2015, 11:54 AM | #4 |
Drives: All things Turbocharged Join Date: Dec 2010
You will want to install an MSD fuel pump booster. You can't do 580whp on a stock pump by itself.
10-06-2015, 12:52 PM | #5 |
I'm prepared to go aftermarket pump just not sure how much I need it to flow to keep up with full bolt ons w cam @ 430 + 150 wet
10-06-2015, 03:01 PM | #6 |
Drives: 2017 Summit White 2SS A8 Join Date: Oct 2013
Just go squash system and never worry about it again if you ever want more
Mod List: Stock (for now) |
10-06-2015, 03:14 PM | #7 |
Drives: 2016 1SS Join Date: Apr 2012
You could go with the ZL1 fuel pump. Drop in installation and just have your tune checked to be sure its all good. From there should not have any problems. That pump will hold over 700rwhp with ease.
Thank you, Ricardo |
10-06-2015, 03:30 PM | #8 |
Thought about that too, thanks
