02-19-2011, 10:35 PM | #1 |
Drives: 2011 IBM 1LT RS Join Date: Feb 2011
Power Window Problem
It's been raining for about 5 days and my Camaro is under cover at home, but at work it was exposed to the rain for a week. Today was the first day of no rain and I rolled both windows down. The passenger side window would not go back up from both the driver control and passenger window controls. The driver side didn't work either but after a couple of clicks it went back up. I had to turn the car off wait awhile, restart and the window went up. Car only has 4K mileage. It works fine now. I guess my questions are:
1- Anybody else experience this? 2- Was it due to the rain/moisture? (It rained like Seattle rain for 5 days) 2-Should I take it in, as it's covered under the warranty? Thanks in advance! |
02-19-2011, 10:42 PM | #2 |
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
You could take it in to have it checked! But if they can't duplicate tue problem then it was a worthless trip! I would give it a while longer to see if it happens again! Could just been a freak thing Tha happened!
02-19-2011, 10:44 PM | #3 |
Drives: Black Camaro 2LT RS with Sunroof Join Date: Jul 2010
happened to me once with only a couple thousand miles on it and it freaked me out. Never happened again since. I dont think we need to worry, hopefully haha.
2011 Blk on Blk 2LT
[x] Perma-grin [x]1000 Watt Dual 12'' Subs (******** Harness) [x]Blacked out Bow-ties [x]AACStyle Blue Footwell Lights. [x]AACStyle Blue LED Dome Light. [x]AACStyle Blue LED Trunk Light [x]Knight Rider 54 Blue LED [X]Valentine 1 Hard Wire [X]Valentine 1 Concealed Display [ ]20 %Tinted Windows [ ]LED Underglow [ ]Rear Footwell Lights [ ]ABL Extension [ ]Camaro RS Projection [ ]Painted Calipers [ ]Glove Box Light [ ]Door Handle Lights [ ]Cold Air Inductions CAI [ ]AACStyle Plasma DRL [ ]AACStyle License Plate LEDS |
02-19-2011, 11:20 PM | #4 | |
No kidding.......
Freaked me out too. I drove 20 miles to a college basketball game and I was like, I ain't leaving my pride n joy in a parking lot with the window down. No F'n way. |
02-21-2011, 07:53 PM | #5 |
Anybody else? Dealer said to bring it in.
02-21-2011, 08:25 PM | #6 |
White Lightnin
Drives: 2010 Summit White Camaro LS Join Date: May 2010
My driver side window has an intermittent problem. Sometimes it don't work, sometimes it does. When I took it in for the scheduled oil change I told the dealer about it and of course the window worked fine...until they drove it around to hand me the keys. They pulled it back in and re-checked it. They said the switch reported to the computer to be working correctly but the techs knew it wasn't. They ordered another switch, $8.00 covered under warranty and I'm waiting for a day off to take my Camaro in to get it replaced. Yeah, its still intermittent...for now. Maybe they got a bad batch of switches at the factory??? Who knows?
02-22-2011, 08:54 AM | #7 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
My 2011 has a similar problem. It is not the index thing. The fast up/down does not work, and if you pull/push too far it says "door ajar". So you have to just barely move the switch for it to work properly. Switch assembly ordered for it.
02-22-2011, 09:07 AM | #8 |
Drives: 2SS LS3 Join Date: May 2010
I think the problem is the window indexing. In most cars, there is no intelligence built into the windows. They go up. They go down. Pretty simple and nothing usually gives problems. With the Camaro, the window has to be 'smart' enough to slightly open or close the window if the door is opened or closed. What probably happened in your case is the 'smarts' got phucked up for that moment which is why a recycling of the ignition reset the window system and solved the issue.
This happened to me once where the window switches didn't work. I restarted the car and all was good, and never failed since. As for the auto up and down, I sometimes find an issue with sensitivity of the switch where it won't respond to auto up or down. It took me some getting used to. I mentioned to the service rep and he never heard of an issue with the switch sensitivity.
2010 CGM 2SS LS3, born: 4/10 |
03-03-2011, 02:43 PM | #9 |
Drives: GM Vehicles Join Date: Jun 2010
Aieaboy and f5journal, have either you had the issue reoccur or have you had your vehicles into your dealerships for this service yet? I just want follow up with your two on the issues you're having. Thank you.
Jeff Morris, Chevrolet Customer Service |
03-05-2011, 02:07 PM | #10 |
Thankfully, haven't had the problem reoccur. I did call the dealer and they said to bring it in. They said they can check the computer to see if there was a power window trouble code that was tripped. Course they said if there's no trouble code, it would be near impossible to figure out. Rest assured, if it happens again, it's going in.
Thanks for all the responses, much appreciated. Last edited by Aieaboy; 03-06-2011 at 12:29 AM. |
09-09-2011, 11:04 AM | #11 |
Drives: 2019 Camaro Join Date: Nov 2010
Similar issues here. I only have about 1500 miles on it if that. I parked and shut the car off. The OCD in me pulls the switches a few times to ensure their all the way up. So inside you hear the click without any movement since they are all the way up. I get out and close the door and find that the drivers door did not fully seat up in the channel.
Get back in and try to cycle the key and then re close the door to see if it moves fully up in the channel... no go. So I then get back in the car and turn the key on to cycle the window up and down and now it won't go back up. Passenger side does the same thing... goes down but wont go back up. Then after enough playing with cycling the key, starting the car, cycling the key some more, waiting (which I think helped the most), the windows went back up and sealed in the track fine. During that time of trying everything to get them to go back up, I experienced where one window worked and the other didn't, then they swapped. A real PIA. Not sure what I am going to get when I go home today. Hope it wasn't my OCD that broke something?
JRunner01
09-09-2011, 12:21 PM | #12 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Happened to me once. Window wouldn't go up.
Its good to re-set your window indexing once in a while. 1)Window All the way down - Hold switch 3 seconds. 2)Window All the way up, - Hold switch 3 seconds.
09-09-2011, 01:29 PM | #13 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
09-09-2011, 01:42 PM | #14 |
This is the fix assuming your not stuck to begin with. It seems more like a preventative measure than a fix. How do you implement this fix if your already in a bad state?
JRunner01
Similar Threads | ||||
Anybody Spray'n their SS yet - nitrous ? | WeeZee | Forced Induction - V8 | 37 | 12-29-2012 09:56 PM |
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
POWER WINDOW ISSUE!! | isaiasrincon | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-05-2011 10:10 AM |
Power steering problem? | Maro99 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 05-24-2011 10:51 AM |
Window hits when openeing door? | AWS-GTAW | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 9 | 06-27-2010 11:43 PM |
