Old 06-10-2015, 07:03 AM   #1
link6189
Drives: United States
shifter question
Hello all, I just purchased a 2010 ss and its got a hurst short throw shifter installed. I like the hurst look and it performs beautifully but I feel it's a little notchy and clunky for everyday driving. After doing some reading I think the factory zl1 shifter is a better option for me. My question is will the hurst handle fit on the zl1 shifter? I want to keep the look that the hurst has but have a smoother more daily friendly shifter.
Thanks
link6189 is offline   Reply With Quote
Old 06-10-2015, 07:41 AM   #2
ZiG
ZiG's Avatar
Drives: 2011 2SS/RS LS3
Sadly, no. But you could try a weighted shift knob and see if that's more to your liking..
2011 2SS/RS LS3
Rotofab CAI/scoop/washer - FE4 conversion - Pfadt ZL swaybars - BMR endlinks - Hurst short shifter - RKSport spoiler
ZiG is offline   Reply With Quote
Old 06-10-2015, 07:55 AM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You could look for a GM factory Hurst take-off and run that. I have one in my 2010 and it is a good compromise. You need the whole assembly.
The GM Performance Parts shifter would be good as well.
Old 06-10-2015, 08:18 AM   #4
dollar14
dollar14's Avatar
Drives: 2010 summit white 2SS/RS M6
try changing your transmission fluid instead of the shifter first.the previous owner could have put heavy weight old school oil or who knows what in there.i had good luck with redline D4.it shift's smoother than the stock stuff did.do a search on here for trans fluid and there are a lot of discussion's about it.
2010 2SS/RS M6,kooks 1-7/8 LT'S with hi flow cats,factory NPP cat back system,ADM performance street c.a.i.ADM built LSA with 750+ package,160 deg. thermostat,mti six shooter shifter,jac fab front license plate bracket and tunnel brace,eibach 1 inch pro kit,ADM exhaust controller,custom ADM performance tune,703 rwhp 704 rwtq
dollar14 is offline   Reply With Quote
Old 06-10-2015, 11:52 AM   #5
gofastscottb
"Track Tuner"
gofastscottb's Avatar
Drives: 2010 2 SS/RS LS3 Camaro
I agree, it is not the shifter (that was my first mod). I changed trans fluid to Driven STF & then the Ram Clutch pedal adjuster & it shifts as good as the old cars with a Muncie & a Hurst shifter. It is a lot easier & fun to drive also.
Regards,
Scott
MPD Racing
MPDRacing.com
gofastscottb is offline   Reply With Quote
Old 06-10-2015, 01:00 PM   #6
Camarotobeornottobe
Drives: 1LE
OP, I'm about to list up a 1LE/ZL1 shifter assembly -- complete with the 1LE suede knob. The only thing you would have to get for your car would be the boot. If you think you want to go that route and want to save some money over new, PM me.
Camarotobeornottobe is offline   Reply With Quote
Old 06-10-2015, 02:23 PM   #7
link6189
Thanks for the replies guys, I think I will try changing the gear oil first. I also have read about the bushing issue with these earlier hurst shifters and mine definitely has the slop in it so that can't be helping right?
Old 06-11-2015, 04:25 AM   #8
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
If yours is the factory OEM Hurst, then no, you do not have a bushing issue. If it's the aftermarket chrome handle/white ball Hurst, then possibly you have a bushing issue.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 06-11-2015, 06:15 AM   #9
link6189
Yes it's an aftermarket chrome handle white ball shifter. Anyone have a link on where I can get the bushings? I looked at the hurst website but I couldn't find any
Old 06-11-2015, 09:01 PM   #10
ckaram
ckaram's Avatar
Support the sponsors
http://www.phastekperformance.com/20...gs-3326030.htm
