Old 08-11-2014, 01:48 PM   #1
CamaroBC
CamaroBC's Avatar
Drives: Cyber Grey 2LT RS Coupe
The Engine Light is on, a GM service center said Warranty is good up to 36,000 miles.
Good thing im at 33?
Not Sure how long the light has been on. Guess I'll take her in to them, see whats going on. She still runs the same though.
CamaroBC is offline   Reply With Quote
Old 08-22-2014, 10:37 PM   #2
kdalters
Nittany Lion in Hogville
kdalters's Avatar
Drives: 2012 Camaro conv.
Mine just came on at 33,000 miles also. Runs fine and fluid levels are ok. Gas cap tightened correctly. Could this be for a recommended service interval?
kdalters is offline   Reply With Quote
Old 08-23-2014, 01:12 PM   #3
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Nope.
TommyTheCat is offline   Reply With Quote
Old 08-25-2014, 08:34 AM   #4
CamaroBC
CamaroBC's Avatar
Turns out i got a code for a coil pack on the engine, and Cat converter code. The guy reset it and it hasnt gone back on since. But I also got an oil change so maybe that was why?
Old 08-25-2014, 09:12 AM   #5
Rock It
Rock It's Avatar
Drives: '12 2LT/RS
i had a coil pack go out at 12K... i would have them look at that a little more... just my $0.02
Mods- "Bo" ported T/B, Apex catch can, Apex scoop and W/W, K&N CAI, Magnaflow axel back, Big Worm vinyl graphics, Vitesse T/C
Rock It is offline   Reply With Quote
Old 08-25-2014, 09:50 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
So they rest the code and send you on your way without fixing the issue!
Go to another dealer and get this fixed properly.
Mods:
Old 08-25-2014, 10:32 AM   #7
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
That's unacceptable. They're probably praying the light won't come back on until your warranty is up. Those catalytic converters are NOT cheap
Old 08-25-2014, 08:45 PM   #8
kdalters
kdalters's Avatar
Put in a tank of gas.... light went out after about 50 miles. I think the previous fill-up must have been poor quality.
Old 08-25-2014, 10:36 PM   #9
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
Your fuel quality and your oil changes are NOT going to cause an electrical problem (ignition coil) nor are they going to cause a catalytic converter or oxygen sensor problem.
Your dealer is hoping to bank on you spending a good chunk of money on those catalytic converters. Those are going to cost well within four digits and then some, I promise you.
Go start a riot. There is absolutely no way an oil change would cause this... Give em hell if they try to BS you like that.
Old 08-25-2014, 10:48 PM   #10
LStick
Drives: 2021 Shadow Gray 1LS
"The Engine Light is on, GM service center said Warranty is good up to 36,000 miles"
File Under- "If it happened once, it'll happen again".
Probably at 36001 miles.
LStick is offline   Reply With Quote
Old 08-25-2014, 10:56 PM   #11
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
+1
I work in the Auto industry and that is just BS by the dealer. Make sure you have something in writing from the dealer so they will cover it if it returns after the warranty expires. My .02 as an ex-service manager as long as I could prove previous issue it was always cover even if warranty had expired. But that was just me and I always looked after my customers.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 08-26-2014, 05:51 AM   #12
baum
Drives: 2013 1LS, 2013 Ram 1500
i agree that is just bs so they dont have to fix it at this time.
baum is offline   Reply With Quote
Old 08-26-2014, 10:49 AM   #13
CamaroBC
CamaroBC's Avatar
ok i will
Old 08-26-2014, 10:50 AM   #14
CamaroBC
CamaroBC's Avatar
No I said it hasnt come back on probably because i also changed out the oil.
