05-23-2016, 10:33 AM | #1 |
BTR Stage III cam swap, what did you replace?
I have some questions on the BTR stage III cam sawp.
1. Did you change the springs, retainers, etc? 2. Did you keep the stock lifters, if not what did you use? 3. Do you use the stock length pushrods? If not (because of swapped lifters, or otherwise), what length did you use? The engine will be essentially brand new when it get swapped. (for an upcoming project). Any help or insight would be appreciated.
--- DarthZL1 - 2014 ZL1 #2095 M6 Black. Bone Stock ---
--- BigNLo - 1996 Impala SS Hot Rod Black. Lots of mods --- |
05-23-2016, 01:21 PM | #2 |
Drives: 2017 SS Join Date: Sep 2011
Assuming stock everything going to BTR cam? Then, Yes you will have to change springs and pushrods, You can use stock lifters. The pushrods length should be measured once the cam is installed and correct length ordered. I believe BTR will require you to change the cam sprocket to a 3 bolt, stock is a single bolt.
2017 SW SS
05-23-2016, 01:30 PM | #3 |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
In addition to mikey's list, consider adding a rocker arm trunnion upgrade. Also, when switching to the 3-bolt cam gear, it's a good idea to remove the stock LS3-style "leaf" timing chain tensioner and replace it with a LS2-style "dogbone" damper.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
05-23-2016, 02:02 PM | #4 |
Drives: '21 ZLE A10 Join Date: May 2012
most people leave the stock lifters because in order to replace them you have to remove the heads. The stock springs, retainers, locks, and pushrods should be replaced with upgraded units. The upper timing gear and timing chain should be replaced. The C5r timing chain is very nice but somewhat expensive through Katech. ARP crank bolt is preferable with a new timing cover seal and crank snout seal. The water pump gaskets can be reused as well as the valve cover gasket seals. Leave the rocker trunions stock according to my tuner and other reputable shops. LS2 tensioner is preferable as stated above.
05-23-2016, 06:21 PM | #5 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
I did everything as mentioned above except I did not put a different timing chain or LS2 tensioner.. Mainly because I did mine at home on jack stands and could not lower the pan enough to remove the oil pump pickup tube to get the chain out. Also the spring style tensioner looked better than an LS2 style IMO
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
05-23-2016, 10:02 PM | #6 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Follow what Stephen said.
You need Cam Springs retainers (preferably Titanium) spring seats valve locks timing chain LS2 damper cam gear gaskets all reusable but optional if you want them. crank bolt pushrods optional but good upgrade. You can actually get the BTR3 cam ground on a single bolt design and then keep the stock tensioner and damper design. The cam gears have different pitch and the chains are different too. Don't mismatch the two chain and damper designs. Either keep it all original or change everything. So get LS2 design chain, damper, and cam gear. Or else get a single bolt cam and keep the stock chain, damper and gear. If you call Brian Tooley he can put together everything for you and send it to your door.
Bryan 2018 ZL1 M6
05-23-2016, 11:12 PM | #7 |
Too much is never enough!
This is what I did, not saying you NEED to do this:
ls2 damper c5r timing chain comp cams trunion upgrade new valve seals cadillac racing lifters Dual valve springs Stephen12ZL1, and ZO6 Bryan are dead on, great advice.
05-24-2016, 12:30 AM | #8 |
Drives: 2014 2SS/RS Join Date: Jun 2013
If you got the cash get aftermarket heads too. Upgrading the valve train while the engine is in the car is a PITA. My back hurts just thinking about it.
05-24-2016, 12:32 AM | #9 | |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
"You" would recommend replacing the timing chain but not the lifters with a new cam? Re-using LS water pump gaskets? No Trunnion upgrade? Why would you ask the tuner and not the engine builder??
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
05-24-2016, 12:34 AM | #10 |
Gaskets can be re used, no biggie, as for the lifters, not necessary. I did mine, because I was rebuilding my engine, and had the heads off anyway.
05-24-2016, 12:34 AM | #11 | |
05-24-2016, 12:39 AM | #12 |
Why would you re-use any gasket? Please give me your professional opinion?
05-24-2016, 12:41 AM | #13 |
Me personally, I wouldn't but they can be reused, they are not the old paper and cork gaskets that they used to be. Why don't you stop being a condescending jerk and offer some constructive advise, instead of just tearing down others.
05-24-2016, 12:42 AM | #14 | |
Edit: Oil pump, not chain. |
