Old 11-25-2013, 07:52 AM   #1
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
NITROUS GUYS
Lookin for nitrous cars. we need a thread . Currently im running cam and 150 shot thur a harris speed works plate. what are ur guys setups and how u installed it and such.
i cut out my spare tire hole right now and gonna go back with a flat plate with a recessed box for my bottle and battery. then thinking about a spray bar of some kind to hide the kit.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 11-25-2013, 11:40 AM   #2
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
why not get the "money maker" kit for Nitrous Outlet? they put the lines through your Intake so its all hidden.
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
Old 11-25-2013, 11:51 AM   #3
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
I'm spraying a 125 shot with a Zex kit, into 12.5 PSI boost from an ECS Vortech Si trim setup.
I just have the nozzle installed in the intake tube just after the MAF sensor. I control timing with an LNC 2000, but since it is injecting into boost after the MAF, the IAT in the MAF doesn't adjust timing up for the intercooling effect, so I really don't need to retard timing much at all.
15 LB bottle in the trunk on the left side. I just ordered a remote bottle opener, if it won't fit for length I might have to drop down to a 10 LB bottle.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 11-25-2013, 12:16 PM   #4
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
nitrous outlet makes a nice mount that puts the bottle on the back trunk wall, here is a pic of one of our recent installs
Joe@CPR.com is offline   Reply With Quote
Old 11-25-2013, 12:38 PM   #5
Brandon@NitrousOutlet
Drives: Fast!
^ Top notch. Thats the install all installers should strive for
Brandon@NitrousOutlet is offline   Reply With Quote
Old 11-25-2013, 12:41 PM   #6
Joe@CPR.com
Thanks man! we sure do a lot of these haha
Old 11-25-2013, 03:05 PM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
nice , ya ive got the lnc-2000 , and nos launcher controller on mine. the money maker is probably what im gonna go with or something from rick crawford.
Old 11-25-2013, 04:20 PM   #8
Drives: Fast!
Thats a clean setup!
Old 11-25-2013, 06:25 PM   #9
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
be alot cleaner with a nitrous outlet setup. if i end up keepin the car . its gonna be a big shot on it next year . with forged bottom end. car should do good its about 3500-3600 lb range right now.
Old 11-25-2013, 07:53 PM   #10
infernometallicSS
infernometallicSS's Avatar
Drives: 2012 Camaro SS Best Run - 10.93@125
This car looks real familiar...
infernometallicSS is offline   Reply With Quote
Old 11-25-2013, 08:05 PM   #11
Joe@CPR.com
What do you know about that install jeff!
Old 11-26-2013, 12:05 AM   #12
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
That looks good!!
Camarojt is offline   Reply With Quote
Old 11-26-2013, 10:48 AM   #13
dan0617
dan0617's Avatar
I'm assuming there is a special pick-up tube in the bottle that allows it to be mounted sideways? Can't mount a normal bottle that way.
Old 11-26-2013, 11:04 AM   #14
Joe@CPR.com
it has a siphon tube in it, nitrous outlet designed the mount so i'm sure it's perfectly fine.
