Solo Performance
Old 01-10-2010, 09:43 PM   #1
asmith10
Drives: Camaro 2LT/RS IBM
Bird Poop Mark
I had a bird poop on the car a day ago, and though I intended to clean it off once i got home, other matters popped up and I wasn't able to get to it until this afternoon when I washed and waxed it. I got the poop off, but there is a spot left behind that not matter how hard I scrub, it won't come out. It still shows up after being waxed as well. How do I get it to go away?
asmith10 is offline   Reply With Quote
Old 01-11-2010, 12:58 AM   #2
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Wash the spot with some diluted dawn and water to remove the wax, rinse, clay bar the spot using car soap/water as a lube, wash the spot again with your car soap, rinse then rewax. That's what I'd do.
The wax wont remove the spot but rather cover it with a layer of wax. The spot left behind is probably a mineral deposit of some sort left behind from the poop, or from the acidity/basicity of the poop reacting with your clear coat. Claying should knock it off, unless its really reactive seagull poo that Ive heard can burn your clear coat. More extensive treatment would be needed then.
Old 01-11-2010, 01:09 AM   #3
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
Exactly. Those more extensive measures would be something like the PC and a polish like Adam's SHR or Zaino's PC Fusion. When you clay, make sure you apply pressure and scrub at the spot. This is contradictory to what you will read on the Internet but the grade of clay that is sold to the average consumer is NOT going to damage your paint. If anything, it will merely mar the paint if you don't keep it lubricated enough but can be easily remedied with a quick pass of the PC and a scratch removing polish.
Here's a quick video of my claying process.
How to Clay
Do you have access to or own a PC-7424?
Junkman2008 is offline   Reply With Quote
Old 01-11-2010, 01:52 PM   #4
DangerZL1
Drives: Future ZL1 Owner
I've successfully removed bird poop marks by using a clear coat cleaner and a swirl remover. As long as the poop didn't etch too far into the clear coat, it will get a lot of the damage out, and if your lucky, all of it. On the other hand, I have a spot on the roof of my car where bird poop ate down to the primer coat. Wax by itself isn't likely going to get all the damage out.
DangerZL1 is offline   Reply With Quote
Old 01-12-2010, 08:21 PM   #5
Chris@glimmerglass
Drives: 2001 S10, 2002 M3
Send a message via AIM to Chris@glimmerglass
Wax won't get any of the damage out unless it is a cleaner wax. The clear coat would have to be cleaned thus requiring claying, polishing, etc., as mentioned above.
Chris@glimmerglass is offline   Reply With Quote
Old 01-16-2010, 03:08 PM   #6
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Bird poo is some nasty stuff, it actually eats the clear coat - therefore requiring you to follow the steps already posted.
I always keep a quick detail spray in my trunk with assorted micro fibers for such an occasion, because the quicker you get the poop off of it the less damage it will do.
2LTRS is offline   Reply With Quote
Old 01-16-2010, 07:13 PM   #7
SS_in_Black
SS_in_Black's Avatar
Drives: 2SS Black over Inferno Orange
+1. I also keep a bottle of water for rinsing first then using the spray.
2SS-RS Black over INFERNO Orange
My bank loves me when I buy a new car every two years
SS_in_Black is offline   Reply With Quote
Old 01-17-2010, 01:00 PM   #8
asmith10
Ok wierd thing happened. Like I said the mark was still there after I washed and waxed it that night. The next morning it was gone..I couldn't find a single trace of it!
Old 01-17-2010, 02:23 PM   #9
scythezo6
scythezo6's Avatar
I came by and buffed it out. You owe me $10 plus travel.
Old 01-17-2010, 04:18 PM   #10
Junkman2008
Were you the mystery buffer or a mystery in the buff?
"Marines - Making the other guy die for his country for over 200 years."
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
Good Paint Scuff Mark Remover fmdog44 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 08-26-2010 03:10 PM
Does your dog eat soap? 2ndgenz28 Off-topic Discussions 24 10-11-2009 05:40 AM
Anyone have issues with clear coat and bird poop? fireresq157 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 23 08-27-2009 01:56 PM
