Old 03-12-2014, 06:19 PM   #1
Matt.Kim
Drives: 2011 2lt/rs
Flashing CEL?
Sorry guys I'm pretty sure this has been discussed before but, while I was driving around my car was running fine, but then when I slowed down my CEL comes on and it starts to flash then me Stability Tract came up for a second and went away. I have read on here that it might just be a loose connection but in my case the CEL at some point keeps flashing then stays solid. The only thing I have done to the engine is put on a ROTO-FAB intake on and a SLPLM2 axle back. Oh and I drive a 2011 2lt.
Matt.Kim is offline   Reply With Quote
Old 03-12-2014, 06:25 PM   #2
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Flashing CEL is a serious missfire being detected.
I would check all your plugs & wires to make sure they're nice and tight/snug. Thats the first place to start looking.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 03-12-2014, 06:29 PM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
I don't think the V6 has plug wires.
OP first thing I would do is either buy a OBD 2 code reader or go to auto zone or advance auto and see if they can read any codes stored.
The Bird is the word!
Old 03-12-2014, 06:34 PM   #4
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Ok, but it still has plugs, right? Could also have a cracked/ripped COP boot, or even a bad coil.
I dont know much about the 3.6 LLT/LFX but if its individual coils, scan the CEL and see what cylinder is the problem. Move that coil from the problem cylinder to another one and if the missfire/CEL code changed over to the cylinder you moved the coil too, then you know that coil is the problem.
Old 03-12-2014, 09:29 PM   #5
Matt.Kim
Drives: 2011 2lt/rs
Okay thanks for the information, I checked everything and I some of the plugs I guess weren't all the way in, after putting them in nice and snug it started up right and nothing seemed wrong but the CEL was still on. Does that mean I have another issue? Like the CEL wasn't flashing nor did the stabilitrack come on.
Old 03-13-2014, 08:01 PM   #6
Matt.Kim
Drives: 2011 2lt/rs
So I got to the dealer and they said that they couldn't duplicate the problem so everything was fixed, but the CEL came back on. Has anyone else experienced this?
Old 03-14-2014, 08:33 PM   #7
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Did you clear the code and then rescan to see what it says the problem is??
If the CEL is on go back to the dealer...they cant tell you they cant reproduce the CEL, lol.
Old 03-15-2014, 09:14 PM   #8
Matt.Kim
Drives: 2011 2lt/rs
Yeah I did. Now they are saying that my cats are going bad....
Old 03-16-2014, 01:36 AM   #9
canecorso69
run ur car not ur mouth
canecorso69's Avatar
Drives: 2013 1LE
You prolly have a P0300, P0420 and P0430 codes. 0300 code is multiple misfire code which was prolly caused by loose plugs which in turn gave you the 0420 and 0430 codes due to raw fuel going to cats. Clear the CEL and drive it for a cycle then scan for codes. FWIW... I could be completely wrong on my assessment as I am not a mechanic.
canecorso69 is offline   Reply With Quote
Old 03-22-2014, 03:52 AM   #10
MLAZ1990
MLAZ1990's Avatar
Drives: 2012 black camaro 2LS
My CEL flashed last night and went away but now the car rumbles/shakes at idle!
MLAZ1990 is offline   Reply With Quote
