Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 02-27-2015, 01:34 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
track junkies.....what timing chain tensioner is in your car?
Just about to change my cam. Have the timing cover off. I have an ls2 dampner sitting here but i had the ls3 tensioner in my car with a big cam and blower at 650ish whp...it still looks fine. Just wondering what yall got in there since youre revving the piss out of it most of the time. Apparently the zr1 has the ls3 tensioner according to factory assembly pics. I already upgraded my timing chain. Im starting to believe its the stock chain that fails first...thanks!
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 02-27-2015, 02:36 PM   #2
Russell James
Russell James's Avatar
I'd use either that LS2 one you have, if new.
Or
http://www.lingenfelter.com/mm5/merc...egory_Code=C38
That's a Cloyes heavy duty one.
I like those styles cause there is nothing to fall apart. That, a C5R Chain, and a 3 bolt cam, and you're pretty bullet proof under the timing cover.
Old 02-27-2015, 06:44 PM   #3
forklord
forklord's Avatar
Drives: 2010 2SS
Anyone have any hard tracking miles with either in?
Old 02-27-2015, 09:24 PM   #4
Synner
Drives: cars
Ls2, works fine.
Old 02-28-2015, 08:31 AM   #5
Russell James
The LS2 style is what Katech and Lingenfelter sell and use. It'll work perfect for you.
The biggest advantage is there is nothing to fall apart.
The LS3 style might be slightly quieter, but is more complex. For racing, you want simplicity and bulletproof. The LS2 style better fits a racing application.
Old 02-28-2015, 10:46 AM   #6
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
I broke my stock LS3 style after my cam swap. Went to LS2 style and it's been fine since.
1977and2010 is offline   Reply With Quote
Old 02-28-2015, 11:10 AM   #7
forklord
forklord's Avatar
Drives: 2010 2SS
Was your chain ok?
Old 02-28-2015, 01:20 PM   #8
1977and2010
Yes chain was fine. C5R btw.
Old 02-28-2015, 01:38 PM   #9
forklord
forklord's Avatar
Drives: 2010 2SS
K dampner it is
