02-05-2017, 11:17 AM | #1 |
Ben Rakers
Polyurethane motor mounts!
Just finished the install on my new BMR polyurethane motor mounts and I'm very happy with them so far. Haven't gotten to drive the car yet but the install was pretty straight forward with only a few hiccups due to the instructions being slightly unclear. But they are built with great quality and look great.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g |
02-05-2017, 11:29 AM | #2 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
Question??? How'd you raise the engine up ?? Did you raise it up by jacking up on the oil pan ??
02-05-2017, 12:02 PM | #3 |
Ben Rakers
Yes, I used my floor Jack and a piece of wood so there was a softer surface against the pan. only had to lift the engine slightly to maneuver them out. I did a front sway bar at the same time.
02-05-2017, 12:28 PM | #4 |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
I don't know if you know but you will feel vibrations in the cabin which is normal with those type of mounts.
02-05-2017, 01:12 PM | #5 |
Ben Rakers
Yes I am prepared for that. Its just a weekend fun car, also a lot of people have said its not too bad.
02-05-2017, 05:59 PM | #6 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Gotta keep us up to date, also has anyone used a set of Torque Solutions billet solid mounts??
Orange Krush II
02-05-2017, 06:34 PM | #7 |
Drives: cars Join Date: May 2011
They're not solid, and yes.
02-05-2017, 07:18 PM | #8 |
Ben Rakers
Will do! I'm looking forward to less moment of the engine and the better throttle response. I know they are not solid, that's why I said polyurethane.
02-05-2017, 08:30 PM | #9 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Let us know. I know on my 4cyl neon they were brutal, maybe they'll be bearable on an 8 cylinder.
02-05-2017, 10:55 PM | #10 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
I have the Prothane polyurethane mounts. They definitely add some NVH. They are not too bad, but noticeable.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
02-06-2017, 09:00 AM | #11 |
Ben Rakers
Will do, from what I've heard its more noticeable at first, but then you get used to it and the break in a little bit. But I'll definitely keep this updated.
02-07-2017, 10:21 AM | #12 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
I know you said you weren't concerned with it, but hopefully the NVH isn't horrible, but I have a feeling it will be quite noticeable.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
02-07-2017, 03:48 PM | #13 |
Ben Rakers
I'm sure it will be noticeable, but worse case scenario I'll buy some stock ones and replace them, they weren't too hard to do luckily. probably an hour to install both. Thanks for the concern, like I said, once I get the car out I'll update this to how they are.
02-07-2017, 04:11 PM | #14 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
LOL...I had a '74 Olds Cutlass with a self built 10.5 to1 .030 455, cam, headers, reverse manual valve body t-400(also self built) connect to a 9in detroit locker with 3.55(also self built)..everything had solid mounts except trans mount which was poly...of course there was NVH...why else would you do this kind of a mod in the first place?
I want to know if the mounts change the engine position at all from factory? any NVH IMHO with this mod is a plus because it is one more direct connection between you and the car....peace out
