09-30-2017, 07:20 PM | #1 |
Drives: 2010 camaro ss Join Date: Apr 2017
Cranking compression numbers?
Anyone know what these cars should have for cranking compression when testing? It’s a 2010 6.2l
09-30-2017, 08:41 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
No less than 100psi on any cylinder and less than 30% variance from highest and lowest cylinders psi.... Per Google
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
09-30-2017, 11:38 PM | #3 |
I know the variance, was just curious if anyone knew a rough number.... it’s clear I have have issues just trying to figure out how many cyclinders. My best is 145lbs my worst is 110. I know compression testers can even make a difference, was looking for a number I should be aiming for
10-15-2017, 06:16 PM | #4 |
Drives: 2010 IBM SS/RS/Stick Join Date: Jul 2010
Not sure if this helps but when my motor was freshly rebuilt, before first firing, I was getting around 180
10-23-2017, 08:42 PM | #5 |
Drives: Z06 wannabe Join Date: Feb 2015
mine put out 180 to 185 on all at 5 cranks, 200 to 205 on all at 7 cranks. 37k miles
Not a perfectly accurate measure that everything is good.
Apex Focused
