Old 08-21-2018, 09:08 AM   #1
suprchrgd
Drives: 2015 2SS 1LE
lowered and rubbing my rear wheel
so I have bmr 1.5" drop springs, toe rods, trailing arms, and sub-frame bushings and rear alignment is at about -1.1 on camber.
My Issue:
When I hit a decent dip or bump in the road I can hear something hit or grind on my drivers side rear wheel along the bead of the tire and rim. The rim is clearly being rubbed/gaulded by something, but I can't find what its hitting or what is rubbing my wheel when the suspension is being compressed...
Any thoughts?
505/465: 416 stroker, landspeed stg 3 heads, 10.5 compression, btr stg 3 stroker cam, E85, kooks 1-7/8" headers,k&n intake,vmaxx tb,mgw,rxt,bmr 1.5" drop springs,bmr poly cradle bushings,bmr toe rods,bmr trailing arms,bmr uca,bmr diff bushings
suprchrgd is offline   Reply With Quote
Old 08-21-2018, 09:39 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
e-brake cable. What size wheels/tires you running with this drop? I had that issue with the passenger side on my dropped car when I went with wider wheels and smaller sidewall, and car fully loaded.
Old 08-21-2018, 09:41 AM   #3
suprchrgd
factory 1le wheels with 305/35/20 on the rear.
Old 08-21-2018, 10:51 AM   #4
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
I had to modify mine and built some brackets to elevate the "spool" that sets inside of a retaining bracket. Basically moved it up 3/4 inch by putting the spool on top of the bracket with another u-shaped bracket I had. I had the same problem occur when I was fully loaded taking a road trip this week and heard the "shhcrape" sound when the coil-overs compressed in a certain way. Turns out some wheel weights were just in the right spot to hit the cable. I try to snap some pics.
gr8daneh is offline   Reply With Quote
Old 08-21-2018, 03:22 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Is there any marks on or inside the wheels' barrel?
Orange Krush II
