05-27-2019, 09:46 PM | #1 |
Drives: 2ss Join Date: Oct 2009
Front end shake ?
Hello camaro friends, so my wife has a 2010 2ss, it’s got 102,000 miles on it. She ordered the car, so it’s a one owner. Anyway it has a slight vibration when the brakes are pushed, kinda like it’s a warped rotor, but I put new rotors and pads on at 90,000 miles. If you push pedal slightly it starts vibrating, but if you stop more aggressively it does not vibrate and might not vibrate for several brake cycles. Could it be a front suspension part or strut ?
05-28-2019, 06:16 AM | #2 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Still sounds like a rotor, and just because it's new does not mean it could be a defect in it. But when you say you can hit the brakes hard and not have issues, and no issues for a while after..... could it be a caliper that needs to be rebuilt? Maybe the pistons is sticking and not engaging the pads to the rotor good.
05-28-2019, 09:44 AM | #3 |
Thanks for the reply, the wobble or vibration feels like it’s wobbling faster than wheel rotation. On two occasions when I pulled away from a stop sign, I could wiggle the steering wheel and the wobble would start to show up. I can get on the brakes kinda firm and wobble goes away. The car does not pull left or right when the brakes are applied.. Thanks again in advance...
05-28-2019, 10:21 AM | #4 |
Drives: 2012 Camaro 2SS/RS Join Date: Mar 2019
Did you burn in the new pads after rotor replacement? Other places on this forum point to that as the main cause of this problem.
I currently am experiencing the same on my 2012. Turned rotors and replaced pads. I didn't do burn in and may end up replacing with new rotors and pads again. |
05-28-2019, 12:11 PM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
With a warped rotor you should also feel the brake pedal pulse. If the pedal is pulsing then perhaps the rotor is not sitting flat against the hub. Was there vibration/pulsing immediately after replacing the rotors at 90k miles?
05-28-2019, 12:34 PM | #6 |
Drives: 15 2lt RS Top Gun Camaro Join Date: Mar 2019
Check the wheel bearings closely, especially the passenger side for play or loosness rough when you rotate the tires. They are a sealed design and at 100k they are probably worn. I see them bad a lot on these newer GM cars.
05-29-2019, 12:00 PM | #7 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Try re-torquing the front wheels to 140 ft/lbs. The rotors may not have seated well. Usually with the rotors I need to lightly sand the rust away from the hubs and back of rotors so that they would seat flat.
Secondly I am guessing wheel bearings or the front control arm bushing, which is fluid filled where it mounts to the frame. Also if the rotors did not wear in evenly, there can be a pulsing effect as the pads "catch" better in certain regions along the rotor similar to if they are warped.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
06-26-2019, 09:21 AM | #8 |
Drives: 2010 2SS/Black Join Date: Mar 2009
I have the same issue. Front end shakes when brakes applied intermittently. I have R1 performance rotors and pads that are fairly new. Took it to the dealer yesterday, they said the steering dampener was leaking and had some play. I'm having them do a front end alignment and bleed the brakes as well.
They wanted to turn the rotors but If I remember correctly your not supposed to turn slotted/vented rotors. Will post the results of the work I'm having done.
2010 Black 2SS L99
Mods: * CAI Intake * Magnuson MP2300 TVS Supercharger/RDS Spacer * Vector Motorsports Tune * Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series * R1 Concepts ceramic pads and slotted/drilled rotors |
07-23-2019, 09:45 AM | #9 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
I have a shake, but it is more at highway speeds. Still has not been diagnosed.
07-23-2019, 01:29 PM | #10 |
Drives: 2010 Camaro SS/RS 6M Join Date: Feb 2018
I have shake when I am driving at highway speeds as well. My alignment is perfect and the wheels are perfectly balance. I was watching a video about similar year corvettes having bushings wearing out. Some company made a delrin replacement and the steering issues went away. I wonder if this could be an issue? I seriously hope it is not my steering rack because holy hell that is expensive!
"A free people ought not only to be armed, but disciplined…” – George Washington
11-04-2019, 02:17 PM | #11 |
Replaced passenger side hub a few thousand miles before brake upgrade. Put on R1 rotors and pads on all four corners, burned in pads and everything has been good for a few thousand miles and then shake developed. I’ve checked out all front end components and they seem good, but I did find .015” runout on pass rotor. Is that enough to cause shake ?
01-25-2020, 10:47 PM | #12 |
Drives: 2010 IBM SS/RS/Stick Join Date: Jul 2010
Any luck? Been having a similar problem and pretty sure it’s not brakes. Gonna look into control arm bushings and ball joints.
Have you looked into the control arms yet?
03-02-2020, 04:55 PM | #13 |
Drives: 2011 CGM Camaro SS/RS Join Date: Dec 2010
Hey did you get that rack and pinion replaced? Did that fix your problem? Did you also have to get a wheel alignment? My 2011 Camaro SS needs the rack and pinion replaced. My car was experiencing at times violent shaking of the steering wheel especially if I hit a pothole. The dealer said it looks like I had a leak and the power steering fluid burned.
