Old 11-03-2014, 03:47 PM   #1
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
Air/fuel meter
I just installed my Air/Fuel ratio gauge. one question, what is the ideal reading ??
If I get into it, it goes to 11.1Name:  airfuel.JPG
gutterball is offline   Reply With Quote
Old 11-03-2014, 04:18 PM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
12:1 in WOT on boost. Richer will rob power, leaner can cause detonation unless you have something to suppress it like Methanol.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 11-03-2014, 04:31 PM   #3
gutterball
gutterball's Avatar
tnx Magnum, so your saying I'm running a little rich
Old 11-03-2014, 05:00 PM   #4
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
Wow where you get those guages ? Reminded me of back to the future .
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 11-03-2014, 05:10 PM   #5
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
It does look like Back To the Future... GREAT SCOTT!!
JantzenOKC is offline   Reply With Quote
Old 11-03-2014, 10:13 PM   #6
gutterball
gutterball's Avatar
The Air/fuel gauge is from wideband, the two on the right (Oil press & Batt volt) are Volt meters purchased on ebay
Old 11-04-2014, 02:28 PM   #7
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I have been at around 14 - 14.5 at warm idle. It does get in the 12's at WOT. I don't have the meter on any more and the car is sitting in the garage. Bambi decided to go to the other side of the road right in front of me. To say the least the car is a mess and Bambi didn't make it. OnStar worked :(
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 11-04-2014, 05:54 PM   #8
gutterball
gutterball's Avatar
Sorry to hear that Pete. Hope everything works out. At WOT, I'm at 11.
Old 11-04-2014, 05:59 PM   #9
Nutbutt
Nutbutt's Avatar
Oh this is just a pain in the a$$ that's all. Just a good reason to look at a 6th gen ?? Did that gauge come with the AFR sensor ?
Old 11-04-2014, 07:55 PM   #10
iceman5730
Iceman
iceman5730's Avatar
Drives: 2011 Camaro 2LT SC/RS CGM
I'm at about 10.2 WOT
iceman5730 is offline   Reply With Quote
Old 11-05-2014, 05:02 PM   #11
gutterball
gutterball's Avatar
Came complete
Old 11-05-2014, 05:03 PM   #12
gutterball
gutterball's Avatar
Thats a little rich, don't you think??
Old 11-05-2014, 05:04 PM   #13
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
A little?
DSX_Camaro is offline   Reply With Quote
Old 11-06-2014, 06:53 PM   #14
Nutbutt
Nutbutt's Avatar
Jim, if your reading 14.4 at warm idle that is normal.
