06-19-2015, 10:18 PM | #1 |
Want 1000hp
what other upgrades can i do to my engine .ive got a magnuson supercharger installed what more do i need to do .cam, head work any help will be appreciated
06-19-2015, 10:29 PM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
You need all your parts to be able to handle 1000hp first. So that's going to take a forged motor, while you're doing that you may as well stroke it to 416ci. Then everything after the motor will need to handle it too. Then you just need a way to push 1000hp worth of air into that motor. Your supercharger can't, so you could add nitrous or just upgrade the supercharger to a larger centrifugal unit. Or our twin turbo kit has no problem supplying that airflow. And then you just need 1000hp of fuel flow and get it all tuned to work together.
06-19-2015, 10:53 PM | #3 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Take maggie off and install twins along with forge a shortblock.
06-19-2015, 11:43 PM | #4 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
A lot of money
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
06-20-2015, 07:28 AM | #5 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
I guess 1000 is the new 500. The internet makes it sound easy so everyone wants it now. LOL.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
06-20-2015, 08:27 AM | #6 |
Drives: 2015 2SS/RS 1LE Join Date: Jul 2014
How I consider LS3 Upgrade costs...
450 RWHP - $ 500-600 RWHP - $$$ 600-800 RWHP - $$$$$$$ 801 RWHP - LOTTERY Remember, that much power doesn't just affect the engine.... Suspension, clutch, fuel, and a whole lot more needs upgrades at the same time. |
06-20-2015, 09:01 AM | #7 |
Disageee.
800rwhp AGP kit for $7500 900rwhp AGP kit with fuel for $8500 1000rwhp add forged motor/etc AGP has done a bunch of bone stock 1LEs, they come in with <2k miles, leave with 790-810rwhp.
Nick
Corvette Z06 -1200ish rwhp |
06-20-2015, 09:19 AM | #8 |
Drives: 1999 Trans Am Join Date: Jul 2009
1000hp on the dyno is different than 1000hp on the street,that lasts.
A good forged motor,fuel system,tranny, A FI kit that can supply enough air. |
06-20-2015, 02:25 PM | #9 |
That's fine to disagree. I'm pushing the same and with a different TT setup. If I had an AGP kit, I'd have the same opinion. Power and safe power are two different things. If you want 800+, you better be looking further than just the motor. Other components of the car need some attention too.
06-20-2015, 02:32 PM | #10 |
Banned
Drives: 2010 Camaro Join Date: Mar 2014
OMG does every post here have to turn into an AGP Commercial?
LOL.... 8500 dollars.... and about 10 g worth of damage.... Motor ... tranny and rear.... But Hey the motor made 900 So much for responsible project builds. |
06-20-2015, 02:38 PM | #11 |
Thank you... Everyone is thinking it. You said it! Hope he gets commission!
06-20-2015, 02:52 PM | #12 | |
Drives: 2009 ZR1 Join Date: May 2010
1000hp on the street is much cooler in conversation than reality. It isn't as much fun as you'd think when the rear is sliding around as if it is on ice. All I can think is "Tires, I'm going to need tires soon." |
06-20-2015, 03:43 PM | #13 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
The guy did say you need everything after the motor once you make the 1000hp. The OP asked a question and in my opinion got a damn good answer.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
06-20-2015, 04:10 PM | #14 |
As Slowhawk said, there is a difference in making 1000, or making 1000 that is reliable and lasts.
To do 1000 that is reliable costs big money. Anyone that says it doesn't probably hasn't done it. It can be done on the cheap, but it wont last and wont be reliable. If you add up 1000hp capable blower or turbo system, built engine, fuel system, tranny and diff upgrades, wheels and tires, and thousands in misc stuff, it gets expensive fast. Every area that you save by not making it compatible, will cost you aggravation and money a bit later.
