Old 08-17-2015, 06:27 PM   #1
PwrAdikt
PwrAdikt's Avatar
Drives: 2005 silverado ss 2010 camaro ss
Big hp turbo cars, manual or 4l80 and why
Im up around the 1000rwhp mark with twins. "Plan in 1300 with race gas" I've got a built tranny and rear but my ram clutch isnt gonna hold up. Thinking of either running a rps triple carbon or swapping to the 4l80. Car is street mostly. No roadcourse or anything. Just slow rolls and digs. I feel it will be faster with the auto but idk. I dont know much about the gearing on the 80 and how turbo's will do with it on the street "this is my first turbo car". Anyone made the swap or wish they didnt??
PwrAdikt is offline   Reply With Quote
Old 08-17-2015, 07:13 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I made the swap, but I'm a blower car.. hands down the best decision I've made! Car drives so well and the peace of mind knowing I won't hurt this trans for a while is great. The trans gearing of the 4L80 will help you spool down low. The lower gear ratio will put more load on the motor.
Just my 2 cents
ttshovel is offline   Reply With Quote
Old 08-17-2015, 08:22 PM   #3
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
Turbo's and auto's go together like mommies and babies!!!!! Seriously do the 4l80 swap it'll be so much faster Done a few Gen v's with it and they all are hooked. Need any tech advice on doing it or parts let me know
Joe@CPR.com is offline   Reply With Quote
Old 08-17-2015, 08:27 PM   #4
onebad1le
Drives: 2013 1le
The fastest Camaro is single turbo and 6 speed
http://youtu.be/AXDMXvpbJMQ
onebad1le is offline   Reply With Quote
Old 08-17-2015, 08:35 PM   #5
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
1281 whp here with twins. Will be M6 forever. No interest in straight line for 8-9 seconds with the tranny running the show. No interest in times at all.
Built this car to relax and have fun, i have plenty of other competitive hobbies, dont want another. YMMV
Just a fun street car that does a little bit of everything real well but built more for the road course than anything else.
Its just me, but going to 150-170 in a straight line is ho hum. Maybe my other hot rod ruined it for me.
Lateral G's are a rush
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-17-2015, 08:44 PM   #6
bct10985
Drives: 2010 2SS LS3, 2013 duramax
That isnt a 4000lb IRS 5th gen either. Trying to get it to hook on the street from a dig is very difficult and getting beat by N/A 5.0 coyotes with slicks and only half the power is embarassing. Ask me how i know
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 08-17-2015, 09:00 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
Thats the Fasest "6 speed manual camaro".
The fastest "Camaro" is ALOOOOOOOOOOOOOOOT faster then a mid high 8 second pass....
Drag racing / trying to really use the power - 4l80E
Having fun with a clutch / road course auto cross - 6 speed manual
bayarea408 is offline   Reply With Quote
Old 08-17-2015, 10:22 PM   #8
climb-101
Drives: 2010 2ss
I'm building a similer set up power wise with twins. for my build I'm out the independent rear and in with straight axle (9" ford) and doing a th-400 trans with a break in it. the th-400 trans are bullet proof and with the brake in them you still shift them but there is no clutch.
climb-101 is offline   Reply With Quote
Old 08-18-2015, 10:24 AM   #9
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
I have twins and a 4L80 and it works fantastic, it depends on your goals, for ET I strongly suggest 4L80, my car is street driven and I track as well, I ride 70 mph @2k rpm, it rides very nice!!!
Jchaluja is offline   Reply With Quote
Old 08-18-2015, 11:51 AM   #10
BradySS
Drives: 2010 Camaro 2SS
I hope you're just trying to be funny.
BradySS is offline   Reply With Quote
Old 08-18-2015, 12:44 PM   #11
Unreal
Drives: 2006 Z06
Auto will be faster, more consistent and more reliable. If those are important to you, go for it.
Nick
Corvette Z06 -1200ish rwhp
Old 08-18-2015, 08:19 PM   #12
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Yea if you're doing digs and straight line racing auto is the way to go. I would also look into a turbo 400 just a suggestion.
Trob85 is offline   Reply With Quote
Old 08-18-2015, 09:48 PM   #13
smokum
smokum's Avatar
Drives: 2010 2ssrs
Anything north of 1000rwhp the only way to go in a straight line is turbo 400 with a gear vendors. I have had this combo in other cars and it is the only way to go. It costs some coin to do it right but is practically bulletproof. I will be going back to this again in my next build. But not in a camaro.
smokum is offline   Reply With Quote
Old 08-19-2015, 12:07 AM   #14
climb-101
Drives: 2010 2ss
th-400, reverse pattern valve body, cheetah shifter, and decent converter is a bullet proof setup. ran that setup in my chevelle for 9 years making around 750 hp, both on the street and strip, it was even a daily driver for a year and ever once had an issue.
