09-17-2021, 02:46 PM | #1 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Garage door spring broke
Went out to the garage and saw a cable hanging down and spring is broke. Door is down so spring on other side is stretched. Should I try to fix it or call someone?
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
09-17-2021, 03:00 PM | #2 |
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
Personally, I'd call someone. Those things can be under a lot of tension and cause serious injury if you're not careful and/or don't know what you're doing (I don't).
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
09-17-2021, 04:51 PM | #3 |
Drives: Chevy Camaro hwse 2018 GMC Sierra 1 Join Date: Jun 2019
Hire it done !! I’ve installed several of these and I even almost got nailed when one got away from me. Save money in the long run HOSPITAL BILLS are expensive!
09-17-2021, 06:12 PM | #4 |
Whosoever Will
If you have to ask, call someone to fix it.
09-17-2021, 07:28 PM | #5 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
Definitely call someone
09-17-2021, 08:02 PM | #6 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Torsion spring or the dual side springs?
Side springs = easy Torsion = call an expert If you have side springs always run the safety line through them.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
09-17-2021, 08:05 PM | #7 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I have the side springs and my cable snapped. I use a rope in its place and has been going strong for a few years now. But I really don’t trust the rope for much longer. Gotta be careful with heavy doors and springs under tension.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
09-17-2021, 08:19 PM | #8 | |
I just had both of my garage doors replaced - one of the installers was telling me how his uncle, who has done installs all his life, just about ripped his thumb off when he took his eye off of one of those tension springs for a second and it slipped while he was pre-loading it. Not something to mess with. I've always heard warnings about the side springs, especially if they snap while the door is down and stretching them. Mostly about damage to the car parked under them, though.
09-17-2021, 08:40 PM | #9 | |
09-18-2021, 01:29 AM | #10 |
I have the side springs. If I can't figure it out this weekend I'll call someone Monday. I'm lucky none of the shrapnel hit the car.
2013 Camaro SS
09-18-2021, 04:33 AM | #11 | |
But yea springs are scary as fuk, I’ve seen plenty of guys at my old mechanic shop get hurt with flying springs when they drop control arms.
09-18-2021, 04:34 AM | #12 |
That’s why I want to get a indoor car cover. They are worth the money
09-18-2021, 10:51 PM | #13 |
Drives: Camaro 1LE Join Date: May 2018
We had one break a few years back after I backed my truck out and closed the door. Even with the safety cable, a piece of the spring went flying around the garage violently evidently. My wife was in the house and heard when the spring broke and heard the piece hitting my toolbox and other items. Luckily it missed her car we think anyways as we never found any damage. The garage door installer recommended changing them out every 10 years if used on a daily basis.
09-19-2021, 03:55 AM | #14 |
Drives: audi Join Date: Sep 2021
Don't know about your spring but they don't last forever. Last repairman told me to spray the spring and all the wheels with silicone spray once a month. Seems to help (those coils rub against each other - add a little corrosion and boing!)
