12-03-2013, 07:51 AM | #1 |
Best way to increase Torque
Pushing 549 rwhp / 488 trq. I want to increase my torque, I feel like it should be in the fives. What's the best way??
Or should I be happy with this number?
12-03-2013, 08:06 AM | #2 |
What all do you have done to your car?
12-03-2013, 08:10 AM | #3 |
knows 2 facts about ducks
gears is the easiest most notable way
12-03-2013, 08:16 AM | #4 |
gears
12-03-2013, 08:17 AM | #5 |
Stock: gears, diff, axles and DS.
Novi 1200sl kit ZL1 fuel pump w/ ADM FPCM LT's with high flow cats Borla cat back ZR1 twin disk clutch Hurst short throw
12-03-2013, 08:22 AM | #6 |
Drives: 2012 2ss/l99 a6, victory red Join Date: Jun 2013
Easy. A big turbo diesel!
2012 2ss l99/a6
CAI, custom catback with flowmaster series 10s |
12-03-2013, 08:37 AM | #7 |
Sounds like gears is where you're headed.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
12-03-2013, 08:41 AM | #8 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Gears...although is does not show a torque increase on the dyno (actually a marginal decrease) you will hit the power band faster. Keep in mind that if you plan on going FI in the future, smaller gears might not work well with that application.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
12-03-2013, 09:14 AM | #9 |
Drives: 2011RedJewel, FI Join Date: Dec 2011
I'd check with your tuner before you make any decisions. I agree, I think your torque should be higher. With a Maggie and basic bolt ons im at 539/508 on a mustang dyno that's pretty stingy. A good tuner will be able to see what you need.
12-03-2013, 09:18 AM | #10 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
12-03-2013, 09:33 AM | #11 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
Stroker kit.
12-03-2013, 09:35 AM | #12 | |
As I recall your running an out of the box Paxton kit on an LS3. You will need to upgrade your Fuel pump and fuel pump module first. Then you can add the JRE Vortech/Paxton Upgrade package and update the tune. this will put you closer to 600 RWHP and 550 RWTQ. Below you will find the dyno sheet of the Vortech Box tune VS. the JRE tune you can see we made significant gains with Just tuning. Then below that you will find the JRE Vortech/Paxton Upgrade and tune dyno graph.
www.jannettyracing.com
12-03-2013, 10:03 AM | #13 | |
12-03-2013, 10:24 AM | #14 | |
Ted.
