06-24-2011, 09:09 PM | #1 |
Drives: IBM 2SS Join Date: Jun 2011
L99 Noise
Well I am just below 900 miles on my new SS and started hearing a strange noise this evening. The sound in the video isn't the best but I was wondering if anyone had an idea of what it could be. It seems to be only coming from the drivers side.
http://s858.photobucket.com/albums/a...8967441944.mp4 |
06-24-2011, 09:13 PM | #2 |
CamaroFans.com
That's pretty hard to hear anything... could it be your car switching into 4 cylinder mode... Give some more details on what you have to do to hear it.. RPMs, accelerating etc...
06-24-2011, 09:16 PM | #3 |
user bann'd
Drives: Chevy SS Join Date: May 2009
I dunno.....sounds like mine....
Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6. |
06-24-2011, 09:40 PM | #4 |
Yea, its kinda hard to hear in that video. Here is another one that is a bit better quality. This maybe perfectly normal but I haven't noticed it before today. I really only notice it at idle. As funny as it sounds, it sorta sounds like a steam engine in person. Thanks in advance for taking the time to listen.
http://s858.photobucket.com/albums/a...8969146745.mp4 |
06-24-2011, 10:33 PM | #5 |
user bann'd
heh, install cutouts..... open cutouts.....never hear sound again.
06-25-2011, 10:10 AM | #6 |
CamaroFans.com
Ok... that one was better, but it's hard to tell where your camera is at... Are you under the hood or standing outside the car. If sort of sounds like lifters ticking which is normal right after startup. Possibly an exhaust leak, especially if you hear it more on one side
I would take it in to the dealer and let them have a listen... |
06-25-2011, 12:01 PM | #7 |
Drives: 1999 Trans Am Join Date: Jul 2009
Doesn't sound good. Bring it to the dealer for warrenty.
06-25-2011, 02:06 PM | #8 |
Its going in Tuesday to be looked at so we will see what they say. Thanks to everyone who took the time to listen and provide their opinion.
06-29-2011, 09:54 AM | #9 |
CamaroFans.com
any resolution?
06-30-2011, 04:24 PM | #10 |
Drives: 2010 Camaro 1SS Join Date: Apr 2011
There is a Technical Service Bulletin out on lifters in the AFM cylinders. not a recall, but worth asking your dealer about. may have to change out AFM lifters depending on duration of sound. This will be warranty covered issue. TSB# PIP4499D i think. search the forums. its in here somewhere.
hope this helps. |
06-30-2011, 04:56 PM | #11 |
Drives: 2017 2SS Hyper Blue Join Date: Apr 2009
Wow-that can't be normal.
06-30-2011, 05:10 PM | #12 |
Drives: 2013 Hot Wheels Special Edition Join Date: May 2009
Almost sounds like a belt pully is loose or maybe the belt is rubbing on something.
06-30-2011, 06:25 PM | #13 |
Sorry for the late response. The dealer said the sound was normal. On the invoice they stated " Found Doc ID 2644797 - This being a normal operations to updated exhaust." From what I was told this sound is due to AFM and some spring loaded valve found in the exhaust?
They stated that it was most noticable while the car was close to a wall.. IE in a drive thru or garage. The first time I noticed it, I was at in a drive thru lol... The video was taken in my garage and the sound isnt' as noticable when the car is in my driveway. So I wonder if AFM was disabled if this sound would go away... |
06-30-2011, 06:36 PM | #14 | |
CamaroFans.com
Well at least you have it documented in case it is something and gets worse someday... |
Similar Threads | ||||
Rear end "popping" noise, need help and opinions | Fiftydriver | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 35 | 09-19-2013 08:47 PM |
Standard vs Automatic Racing | HarrisraTx | Dragstrip and Launch Techniques Discussion | 74 | 10-29-2010 09:26 PM |
knocking noise at a slow roll - L99 | wade | 5th Gen Camaro SS LS LT General Discussions | 8 | 07-15-2010 03:41 PM |
lifter noise on start up with L99 | djs | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 07-24-2009 01:38 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
